ABS, Traction Control and other Light
I have just bought a 02 disco II, I was pulling into a parking lot and I had three lights on the dash come on I know two of them put as I am new owner I can not remeber what the other one is, I turned the vehicle off and restarted and all was good, I have not been able to reproduce this problem. I have scheduled to take to the shop on Friday, Question what should I make sure they check to make sure this problem if it is a problem gets fixed.
on
RE: ABS, Traction Control and other Light
Don't take it in if the lights are not on. Especially don't take it to a dealer unless you have deep pockets and won't mind them throwing lots of parts at your truck.
Do you have a small shop that has a scanner capable of reading ABS codes, if not fine one.
Are your breaks squeaking and or do you have alot of brake dust on your wheels?
Ijust experiencedthe same problem yesterday, and will take my 04 disco to a local shop today. However, it'sNOT the same exact three amigos. I had the TC and ABS lights on, but instead of the Hill descent light, it's the Brake light that came on. But my handbrake was not engaged at all.
I turned the disco off, and after a few minutes, turned it back on. The 3 lights were now gone.
Also,several hours after the "light" incident, i was at a full stop then began to accelerate. I heard a clunking noise. Which i am assuming is brake-related (full assumption on my part- as i am clueless about).
My brakes have been squeaking all the time, and for about a month now. I have some brake dust, but even if the wheels are clean, they still squeak. Loud.
I will have my mechanic get the codes.
Second2None
12-06-2010 05:26 PM
gamecockdisco
07-12-2010 08:34 AM
rodrick smith
04-13-2007 06:09 PM
