ABS, Traction Control and other Light
Old May 21, 2008 | 09:27 AM
troubled's Avatar
Default ABS, Traction Control and other Light
I have just bought a 02 disco II, I was pulling into a parking lot and I had three lights on the dash come on I know two of them put as I am new owner I can not remeber what the other one is, I turned the vehicle off and restarted and all was good, I have not been able to reproduce this problem. I have scheduled to take to the shop on Friday, Question what should I make sure they check to make sure this problem if it is a problem gets fixed.
Old May 21, 2008 | 11:26 AM
Camdisco24's Avatar
Default RE: ABS, Traction Control and other Light
Those three light are famously called "The Three Amigos". Do a search for that at the bottom of the site and you will find tons of info on it. It could be as simple as a messed up sensor.
Old May 21, 2008 | 11:49 AM
Don't take it in if the lights are not on. Especially don't take it to a dealer unless you have deep pockets and won't mind them throwing lots of parts at your truck.
Do you have a small shop that has a scanner capable of reading ABS codes, if not fine one.
Are your breaks squeaking and or do you have alot of brake dust on your wheels?
Old May 21, 2008 | 12:05 PM
troubled's Avatar
I am taking it to my local indy as they have been good, there is a good amount of brake dust on the fronts and there is a slight squeak in the brakes.
Old May 21, 2008 | 12:31 PM
suplada's Avatar
Ijust experiencedthe same problem yesterday, and will take my 04 disco to a local shop today. However, it'sNOT the same exact three amigos. I had the TC and ABS lights on, but instead of the Hill descent light, it's the Brake light that came on. But my handbrake was not engaged at all.
I turned the disco off, and after a few minutes, turned it back on. The 3 lights were now gone.
Also,several hours after the "light" incident, i was at a full stop then began to accelerate. I heard a clunking noise. Which i am assuming is brake-related (full assumption on my part- as i am clueless about).
My brakes have been squeaking all the time, and for about a month now. I have some brake dust, but even if the wheels are clean, they still squeak. Loud.
I will have my mechanic get the codes.
Old May 21, 2008 | 12:51 PM
Check your brake fluid level, that is what will turn on that other brake light.
Squeaking brakes/ dust on the wheels will cause the trio to come on, so deal with that before you spend alot of money at the shop.
newfrl
Freelander
16
Aug 27, 2020 06:55 AM
grizzdog50
Aug 16, 2014 10:52 PM
gamecockdisco
Jul 12, 2010 08:34 AM
rodrick smith
Apr 13, 2007 06:09 PM
