AC Fan making a buzzzz
Old May 14, 2009 | 02:33 PM
Camdisco24's Avatar
Default AC Fan making a buzzzz
When I have my AC on anywhere from level 4 up to Max it makes a deep buzzing sound. I believe its the fan making the sound because when I turn it down the sound goes away. What could be causing this? Is there a quick fix?
Thanks guys,
Cam
Old May 14, 2009 | 03:03 PM
okdiscoguy's Avatar
Take the fan out and make sure you didn't suck a leaf in...
Old May 14, 2009 | 03:07 PM
sforb's Avatar
Mine did the same thing, under the passenger side kick panel, unplug wires, take three screws out,fan will drop out easy, clean out leaves and cab filter whats left of it. check for play in hamster cage. If still bad order used one from roverland parts. easy job!!!
Old May 14, 2009 | 03:18 PM
Camdisco24's Avatar
Thanks guys, i'm going to go do that now.
I'll post back.
Old May 14, 2009 | 03:53 PM
Camdisco24's Avatar
whew... that fan was not easy for a 6'5" person to get to!
But I did eventually, I there was a long strand of what looked like hay (and other little things) in there causing it to vibrate when I had it on full blast. Thanks for the advice. Another issue... Solved.
Rock Sing
Mar 19, 2013 09:21 PM
Eak69
Apr 6, 2010 04:50 PM
rover1978
Sep 26, 2009 09:05 PM
jmt
Jan 14, 2008 05:01 PM
