AC Fan Not working
About a month or 2 ago I was driving around and my air conditioner was blowing just fine on all fan speeds and i parked it for about 20 minutes and when I started driving again I noticed my ac isn’t blowing. I feel there’s cold air sitting in there, but the fan isn’t blowing it out no mater what setting I’m on. Ive just kept my windows down to keep it cool but now want to get this working before it gets cold out. What should I look at first?
Check blower motor fuse, then remove lower panel and inspect the wiring going to the blower. There is one connector that tends to melt. Blower Motors are 30-50.00 for a brand new one.
New one is an easy swap - pull off the panel under the glove box and it’s held in by three screws. You don’t need to remove the glove box.
Make sure the screws are tight when you reinstall or it’ll make noise.
About 8 years ago I had the same problem, threw a motor at it, checked wiring, climate panel, nothing. Turned out it was the circuitry in the interior fuse box. Found a second hand box, motor worked from there on out.
Rhys
Rhys
There’s a connector that was fried so we just cut that off and hooked it straight to the battery and it started blowing so we’re just gonna connect it differently
Last edited by Kadin Wallner; Sep 5, 2020 at 11:59 AM. Reason: Found something out
