AC/Heater "Blower" Intermittently stops
What used to be an intermittent problem has grown to become more frequent.. almost persistent now.
The fan for the AC/Heater will cut out. If I wiggle the switch it will come back on? When this happens, it sounds like there is a relay "Clicking" Where should I start with this?
thanks
matt rickman
colorado
thanks
matt rickman
colorado
RE: AC/Heater "Blower" Intermittently stops
Yeah mine does that on max fan setting only. I just switch to 3 and then back again or just wiggle the switch and it's OK again for several days. I suspect my switch is going bad but it's not been enough of a problem for me to worry about it, yet! Been like that for two years now.
2000, ac, blower, connection, cuts, discover, discovery, fan, heater, ii, intermitent, intermittent, intermittently, loose, range, rover, working
