AC leak
Old Sep 12, 2008 | 11:42 PM
midessa7's Avatar
Default AC leak
Hi everyone, I'm new to this site and i just picked up my 2000 Discovery and I just noticed that the vent on the Passengers side floor leaks clear fluid when I run the AC. I was told that the drain hose for the AC is probably clogged. I just can't seem to find any hose under the vehicle in that area.
midessa7
Old Sep 13, 2008 | 09:35 AM
Default RE: AC leak
There are 2 hose ends/nipples, one on either side of the tranny, coming thru the floor. Find the nipples, maqke sure to use a flash light or you won't see them
If you squeeze yjr nipples, this will usually open them up, otherwise a small wire may be in order.
Old Sep 13, 2008 | 03:06 PM
midessa7's Avatar
Default RE: AC leak
Thanks Mike, I'm going to go look for my nipples and give them a squeeze. I'll let you know how it turns out.
midessa7
ZMonet
Jun 24, 2016 04:00 PM
tito5590805
Sep 27, 2010 11:32 AM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
rgrizzard
Mar 6, 2008 10:16 AM
