Accel 8mm universal wire set?
Old Jan 16, 2012 | 02:03 PM
elrocha69's Avatar
Default Accel 8mm universal wire set?
I was wondering if an accel 8mm universal wire set that you cut and crimp yourself would work well on this truck. It worked very well on my BMW, and seeing as this is an old GM design the wireset will fit well considering I will be cutting and crimping them to the exact length of the factory wires.
Old Jan 16, 2012 | 03:07 PM
kenk's Avatar
Never tried the accel on a LR, but I got these on my '98 and like them so much, I am getting them for my '04
IGN 790 Kingsborne Spark Plug Wires Ignition Wire Set - Kingsborne Ignition Spark Plug Wires Sets made in the USA
Old Jan 16, 2012 | 04:56 PM
elrocha69's Avatar
Not bad! they are priced about the same as the accels except I don't have to make them myself! I am going to order some. Thanks for the link. I even found some wires for me Euro Spec e23 BMW 745i turbo (which was never sold in the U.S. by BMW), which are extremely hard to find stock, let alone a better aftermarket set. these have a pickup sensor on the #1 wire that is important to the car running right at full boost. I will have to spread this to other forums.
Old Jan 16, 2012 | 05:16 PM
ebg18t's Avatar
Wow those king borne are cheap. Is the quality compatible to the magnaore?
Old Jan 16, 2012 | 05:45 PM
Not even close! I know, a rash statement but in this world, you get what you pay for and until you can get 9 or 10 years run, like I have with my Magnacors.
Time tells all.
Old Jan 16, 2012 | 08:34 PM
elrocha69's Avatar
They sure are cheap for our application, but not so much for my 85 745i at close to $300 a set for 6 plus the coil wire. Gotta be better than the replacement parts from the local autoparts store. I had great results from the Accel 8mm wires I made and put on my 86 BMW 325. Better power and they look great (I got the blue ones)
Old Jan 16, 2012 | 09:28 PM
kenk's Avatar
Time tells all.
Guess I will have to chime back in in 6 years, since I have "only" had mine 3-4yrs (w/out a problem).
Old Jan 16, 2012 | 09:30 PM
elrocha69's Avatar
I'm going to give them a shot when it is time to change my wires.
Old Jan 16, 2012 | 10:51 PM
handsome rob's Avatar
I used the Accel's on my D1 and my P38 without issue. They are kind of a pain to make but I do like the fact that I can route it a little different if I want due to added items under the hood.
I have never kept a car for more than 5 years so if they last at least that long that is all that matters to me. Plus I am kind of a every two years replace kind of guy anyways.
gbob
Jan 6, 2020 11:44 AM
filbs
Off Topic
Jun 13, 2012 03:15 PM
kgrab
Jun 2, 2011 01:51 PM
TheRedRockDisco
May 22, 2010 10:43 AM
adwarren78
Mar 24, 2009 08:00 PM
