Acceleration Noise
Old Mar 20, 2011 | 02:11 PM
wa's Avatar
wa
6th Gear
Default Acceleration Noise
I have an 03 Disco II with 60k miles on it that has been well maintained recent oil change and 60k maintenace. I drive it maybe less than 300 miles a month. So yesterday I started driving and as I gradually accelerated its starts making a rattling noise by the front passenger side. As I am driving it goes away until I give it some gas to accelerate. I was wondering if anyone has experienced this before or may know of what may be the cause.
Thanks for taking the time to read this.
Will
Old Mar 20, 2011 | 02:21 PM
mwindth's Avatar
Lightbulb has your front drive shaft been re-built with greaseable parts?
Will
drive line slack...or has your front drive shaft been re-built with greaseable parts? If not, STOP driving immediately and read the ""Write ups" and "How To" sticky section above:
https://landroverforums.com/forum/ge...rebuild-29302/
https://landroverforums.com/forum/di...ld-done-30781/
Old Mar 20, 2011 | 02:33 PM
wa's Avatar
wa
6th Gear
mwindth,
I'm not sure, I'm not a mechanic. I know someone who is an ex landrover mechanic who now works at Toyota. I left him a voicemail so I can meet up next week. I drive about 20 miles a day so will this be ok to drive?
Will
Old Mar 20, 2011 | 02:59 PM
humroot's Avatar
mwindth,
Will
Well, if it what mwindth thinks it is, then NO, it is not OK to drive at all. On the front driveshaft there are 3 u-joints (universal joints). Each one of them should have a zerk (grease fitting). It is a little nipple that will either stick out from the end of one of the 4 sides of the u-joint, or it will be in-between 2 of them. Just get under the front of the truck and you can check very easily.
The problem with our front drive shafts is that they came from the factory with "sealed" u-joints (ungreasable). With the u-joints being so close to the catalytic converter, they heat up A LOT and eventually fail. When they do fail, more often than not it is at high speed and the loose driveshaft will punch a hole in the side of the transmission. This happens more than you would think. So if you HAVE to drive it, I would make it a short trip to the mechanic or a driveline shop to have the u-joints replaced if they are original. What will be a few hundred dollars will turn into thousands of dollars if it fails.
Old Mar 20, 2011 | 03:03 PM
mwindth's Avatar
exactly...X2
Old Mar 20, 2011 | 05:10 PM
wa's Avatar
wa
6th Gear
All,
Thanks for taking the time to reply and providing the information. I won't drive it since I have another car until I can take it to be repaired.
Will
Old Mar 20, 2011 | 06:30 PM
DiscoRover007's Avatar
I have a question in addition to the OP's post. When the drive shaft starts going bad, and a noise or rattling starts to occur, should there be any visible signs that the u-joints are going bad? Would there be a way to tell from looking at the outside of the shaft?
I ask because I just removed my front drive shaft and I'm about to replace the u-joints and center bearing kit. But something I noticed is that the drive shaft looks new, like it's been replaced before.
Old Mar 20, 2011 | 06:33 PM
Bundu's Avatar
Banned
There may be visible signs, some people have posted photos where the u joint cups have started to disintegrate.
If ALL your u joints on the front drive shaft have grease nipples then it has been rebuild, otherwise not.
Old Mar 20, 2011 | 06:37 PM
Yeah mine only has 1 greasable u-joint from the factory. I just think it might be possible that the dealer replaced the shaft entirely at some point. I'm not the original owner. What about the 1 u-joint with a grease nipple? Is that still good and can it be reused? Or should I replace that as well for good measure. I bought 3 Neacpo U-joints with zerk fittings at the end caps.
Old Mar 20, 2011 | 06:47 PM
Bundu's Avatar
Banned
Pump the existing one full of grease, see if fresh grease comes out at all 4 cups. If not then think about replacing it. I would just replace it since you have a new one, and it only takes a couple of minutes once you get the hang of it.
