Access of flywheel to Convert Bolts via oil pan access?
Old Sep 20, 2012 | 04:08 PM
0304Disco's Avatar
Default Access of flywheel to Convert Bolts via oil pan access?
Has anyone ever removed the Fly wheel to torque converter bolts using the access plug holes on the back face of the oil pan. Looks to be a major pain and the only way I've removed these bolts is by dropping the oil pan. Just curious on others experiance.
Old Sep 20, 2012 | 09:19 PM
Bkreutz's Avatar
I have, it's not a big deal, I just used a socket and ratchet on the front crank bolt and turned the engine over to line up the bolts. I don't pull the oil pan when I'm going to be working on the trans. (too much extra work)
Old Sep 21, 2012 | 05:43 AM
drowssap's Avatar
no need to remove the oil pan
Old Oct 15, 2012 | 10:23 AM
lr2001silver's Avatar
Banned
Has anyone noticed that they were missing any off these little bolts while doing repairs? I have a buddy replacing a trans and on one truck he only had 1 bolt and on the donor there were only 2 bolts. Seeing two in a row make me wonder if it is common for them to vibrate out or what? Trucks are a 99 & 01 with close to 130k on them
Old Oct 15, 2012 | 01:48 PM
RoverMasterTech's Avatar
Yeah This is a symptom of shadetree repair. You need to screw all 4 bolts in about 2 threads then start tightening them. The shadetree guy puts one bolt in drives it home and then strips the next 3 out trying to get them to thread in misaligned holes.
Old Oct 15, 2012 | 02:25 PM
Banned
Hmmm ok thanks brother
Old Oct 15, 2012 | 03:16 PM
0304Disco's Avatar
If they came lose they should be sitting the the bottome of the bell housing.
I guess its possible for them to come lose but you should place thread lock on the.
The torque is 37FTpds so the do have a decent force holding them in.
Old Oct 15, 2012 | 05:16 PM
jfall's Avatar
Probably a good idea to get the torques exact.
Or else the flex plate - flexes too much and metal fatigue will then wreck the flex plate.
Did this to a Ford inline 6 in my younger days "cause I did not learn it" and there was no internet in ancient times.
But, there were vacuum tubes, hippies and woodstock.
tdmadlem
May 21, 2015 06:09 AM
0304Disco
May 26, 2013 11:59 AM
MrFlea1
Jan 25, 2012 10:58 AM
Spencerfitch
Sep 14, 2010 08:47 AM
absolute_offroad
Jan 8, 2007 06:08 PM
