Accessing Seat Belt
Old May 12, 2008 | 05:39 PM
Rick9Plus's Avatar
Default Accessing Seat Belt
The driver's seat belt in my 2001 Discovery will not extend or retract. It is just locked in place. I would like to get at the seat belt mechanism to see if something is jamming it (before spending $450 to have it replaced.) Can someone tell me how to remove the plastic cover over the driver side door post between the front and back seats? I am talking about the vertical plastic that covers where the seat belt runs. Any help would be appreciated.
Thanks,
Rick9Plus
Old May 12, 2008 | 06:33 PM
Default RE: Accessing Seat Belt
DO NOTMESSWITHTHESEATBELT MECHANISM, it is gas charged and can explode in your face and could kill you.
Spend the money and have it looked at by a pro, somethings you just dont want to mess with.
Old May 12, 2008 | 10:02 PM
roverguy7's Avatar
if it wont retract either, its most likely just jammed, folded over where it goes through a roller, try pulling out on it hard, dont pull against the plastic, but straight out, see if it works, if not, pull your door seals off around the pillar, youll see little metal clips, pull these loose from the door jam, and the piece will kind of pop off and almost fold in the middle, top has to come down. the belt itself is not charged, no worries there, but be careful with that trim, you dont want to break it
Patrick
Oct 17, 2023 03:39 PM
Grover11
Dec 26, 2014 04:59 AM
annenap
May 2, 2014 01:38 PM
keoni004
Nov 9, 2012 01:10 PM
Roveroh
Feb 10, 2009 12:04 PM
