Accessories not working unless engine running.
Old Oct 20, 2021 | 09:55 PM
Gonow's Avatar
Default Accessories not working unless engine running.
My accessories (power windows/seats, radio..etc) won't work unless engine is running. What gives? In the fuse diagram there are multiple "ignition auxiliary circuits relay" both under the hood and under the steering wheel. Could one of those be it?
Old Oct 21, 2021 | 02:06 AM
The Deputy's Avatar
I'd start by checking all fuseable links and fuses in engine compartment fuse box, then all fuses in drivers compartment fuse box. Swap around a few relays and see if anything changes...but...truthfully...it sounds like an ignition switch issue.
Old Oct 21, 2021 | 10:04 AM
Gonow's Avatar
All fuses are good. I also checked all the relays that say "ignition auxiliary circuit" and they're good too. Would a bad ignition switch cause this to be the only symptoms? The car starts fine.
Old Oct 21, 2021 | 10:49 AM
redwhitekat's Avatar
maybe your ignition switch is acting up, try playing around with that
Old Oct 21, 2021 | 05:20 PM
The Deputy's Avatar
Yes, vehicle has 12.6 battery voltage while off...if battery in good condition...and 13.6/14.2 while running. So, bad/corroded contacts inside ignition switch can be overcome by the voltage increase.
Old Oct 23, 2021 | 02:20 AM
Gonow's Avatar
Issue resolved. Turns out it was a low voltage battery which was caused by a bad alternator mega fuse. I was essentially driving around on battery only for 3 days...
zacelliott
Jan 9, 2022 09:17 AM
Corstrat
Oct 1, 2021 09:18 PM
klandrith
Mar 4, 2020 08:01 PM
Camdisco24
Sep 2, 2015 09:09 AM
bballjames
Jul 16, 2012 02:51 PM
