ACDELCO oxygen sensors any good?
Old Mar 14, 2009 | 03:33 AM
IDAHODISCO's Avatar
I know but my arm is to big and I'm 5'11 190 pounds and all that weight is in my belly LOL!
I just cant reach the back clip on the harness, I am a electrician by trade so I think maybe some cool spade terminals would be cool with some shrink wrap with a little connector grease that would also make for a easy future swap out!
Old Mar 14, 2009 | 10:26 PM
Rover Curious's Avatar
If you are an electrician by trade, I assume that's mainly AC that you deal with. In my experience with automotive electrical, the less connections the better, and you would be adding a connection to a sensor harness that is dependent on voltage for things like fuel/air ratios. Adding a connection in the mix may change your voltage being transmitted to the ECU enough to cause your mileage to suck, or for you to run lean and run the risk of engine damage. Here's my advice, and bear in mind, I'm 5'9", and weigh upwards of 220. Invest in a good set of 8k pound ramps and a cheap creeper. That's how I changed mine, and I had hella room to move around under there.
ITMagician
Sep 20, 2015 08:47 PM
jsyonker
Sep 4, 2011 06:01 PM
topel98
Nov 18, 2007 06:48 PM
adowgiert
Feb 2, 2007 09:11 PM
riebs
Aug 21, 2006 11:48 AM
