ACE Leak up front
I'm trying to trace where my ACE system is leaking; it's definitely in the front around the power steering pump. Does the ACE have a connection block in that general area and how do I get to it?
It's probably one of the two lines from the ACE pump. They run from the pump to the valve block under the passenger side door. Feel the hoses and see if its wet anywhere. I had the rubber section give way years ago and had to replace it.
earlyrover
Apr 30, 2013 03:33 PM
