ACE Lines and bleeding the ACE system
I have a 2000 Disco II with 84000 miles on it.This weekend,one of the rear ACE lines broke (from rear acuator to valve block).I would like to know if anyone knows where to purchase these lines without taking out a second mortage( dealer).and how to bleed the system once I install them.
Take out the second mortgage!!
If you can't find a used one, then the dealer is your only hope. To do a full bleed, like what you are describing, you;ll need a T-4 scanner or equal to active the sytem and refill it.
Any Ideas on where to find them?Also,when I looked at my lines,they seemed to be one piece.When I talked to the parts guy at my Land rover dealer he said the pic showed as two piece for the low pressure and two piece for the high preesure side.Any info?
