ACE Not working: Programming Error
So, the ACE bulb is on and does not seem to be willing to go out. The pump sounds like it is working, I can hear it when I switch on the engine and also it keeps on pumping a little after I switch off the engine. I have tried replacing the transducer on the unit underneath the car since I think its a common failure point. We connected it is to a computer and all we got is 'ace programming error'. Would it be possible that the ace ecm is dead, or dying? We also noticed that for some reason the previous owner had removed the ace fuse altogether.
There is also a slight leak on the unit underneath the car - do not think it is the cause of the issue and I will only try to fix it if I can get the ace working...
any thoughts?
any thoughts?
any thoughts?
any thoughts?
As D2's get older and highish mileage they invariably suffer with ACE problems, hence I excluded ACE from my D2 when new. ACE runs at high pressure and any leaks wherever can cause issues.
https://www.google.fr/search?q=what+...hrome&ie=UTF-8
Interested to hear about this issue. I'm fixing a truck with ACE and somehow the owner is not running it anymore. The pulley was bypassed using a standard pulley and its a 2000 year model. Not sure if 2003 have them. Lights associated with it is lit. Impressive model since it has self leveling and ACE. It has all the oil cooler installed. Seems to be more to fix. lol
tsuyoi
09-22-2020 10:37 AM
