ACE Pump May be Empty- LOUD Whining
Old Nov 28, 2009 | 04:23 PM
Disco2Fever's Avatar
Default ACE Pump May be Empty- LOUD Whining
Hey guys,
I recently learned that that "ACE" system on my '04 HSE requires attention.
Today, I had to park on a huge ditch bank. My E-brake held it strongly, so there was no force on the tranny.
Still, when I backed down, my ACE pump starting whining LOUDLY for about 35 seconds. I was in the middle of nowhere, so I drove on after it stopped, and it did fine on the way home.
I just went to fire it back up, and SAME noise. I confirmed once again that it's coming from inside the blakc plastic box under the driver's side doors, and killed it.
Any ideas? Did I make a boo-boo?
THANKS!
Pat
Old Nov 28, 2009 | 05:17 PM
The ACE pump is under the hood, it is just like a power steering pump.
The air compressor for the SLS is under the truck.
http://www.roverparts.com/Parts/RQG100041.cfm
Old Nov 28, 2009 | 08:01 PM
Well ain't that a turd burd! So I wonder what the heck is whining so bad?? I mean, it's frawkin' LOUD as shiii.
Old Nov 28, 2009 | 09:42 PM
Where exactly is it coming from? Does it only happen when you start the truck? Only when the engine is cold?
Old Nov 29, 2009 | 06:17 PM
Didn't do it today... I'll keep you posted!
THANKS!
Pat
Old Nov 30, 2009 | 10:23 AM
Stop driving it and send me your number.
Your ACE control unit is on the passenger side, under the frame, the SLS is under the drivers side.
You need to figure out what is wrong before you burn something up driving it.
Old Nov 30, 2009 | 11:48 AM
It's actually coming from under the hood- I'll take pics later and show you guys.
Pat
Old Nov 30, 2009 | 01:10 PM
Sounds like you SAI pump then Pat, under the hood, passenger side, only happens when you start the truck and it has sat for a hour or more, sound's kinda like a vacuum cleaner.
Yes?
Old Nov 30, 2009 | 01:49 PM
Spike, that's exactly what it sounds like and where it is- I felt around to try to find where it was sucking or blowing, and couldn't feel anything.
What's the SAI pump all about?
Old Nov 30, 2009 | 01:53 PM
Tons of posts on this Pat.
The SAI pump works like a blacksmiths bellows, it forces fresh air into the cats to help them heat up.
Cold cats do not work as well as hot cats, so they force air into the exhaust when the trucks engine temp is bellow "X" degree's.
There is a foam filter on it, when that filter gets clogged it needs to be changed, you can use the foam filter from a lawn mower or from a window a/c unit.
