ACE system leaking bad...
Old Apr 27, 2010 | 02:43 PM
greenwade's Avatar
What do you mean by "power scrub" mike? I have tried the engine cleaner as well as rags but i do not like to use any sort of pressure around the motor, i am worried that it will get water into places it should not be or knock something loose.
Old Apr 27, 2010 | 05:52 PM
On a D2, you can power scrub the entire vehicle without any worries about electrical issues. I go to the local do it yourself car wash once a month and clean mine with the cold water rinse, works great and everything is clean so you can keep track of any new oil leaks popping up.
Old Apr 27, 2010 | 06:09 PM
greenwade's Avatar
fair enough mike, ill trust you on this one. I just have this little voice in my head that keeps telling me, "no pressure washing under the hood". But i normally do not listen to the voices in my head, so why start now.
Old Apr 28, 2010 | 07:52 AM
It is OK to listen to those voices in your head, just don't answer them back.
Old Apr 28, 2010 | 01:23 PM
fsix's Avatar
Default Leak Found!
Hi,
I'm currently dealing with the same problem. I was able to track mine down a little easier though, a bolt (from who knows where...) fell down and was rubbing against the steel line for the ACE under my oil cooler. I had to remove the rad, engine cooler and gearbox oil cooler to get at it. Now that I've found the source, any suggestions on how to seal it? or is this something where the entire line needs to be replaced?
Thanks,
Old Apr 28, 2010 | 04:49 PM
Replace the line, I don't think you can splice a section, too much pressure.
Old Apr 28, 2010 | 06:08 PM
greenwade's Avatar
so some new information. It seems like the leak must be up high, reason that i say this is because after washing the engine compartment it is obvious that the PS fluid is dripping on the serpentine belt because it is being flung onto the hood. I hate trying to find leaks....
Old Apr 28, 2010 | 07:37 PM
How about the pump, could it be leaking?
Old Apr 28, 2010 | 11:50 PM
greenwade's Avatar
I do not think so mike, but i could be wrong. I will pull it off tomorrow or friday and take a look at it.
Old Apr 29, 2010 | 03:14 PM
fsix's Avatar
Any suggestions on tracking down a part number for that line? I've looked through the RAVE manual and couldn't find one.
Thanks,
