ACE valve block seals
Old Feb 2, 2024 | 09:59 AM
HammyMc's Avatar
4th Gear
Default ACE valve block seals
I posted a while ago about my ace leaking. I found the leak, the rear pipes at the valve block. The seals have gone. I have new seals to go in.All my pipes look in good condition, so hopefully new seals will fix it. My question is this: when the bolts are taken off & the plate slides away from the block is there rearward movement in the pipes to take them out of the valve block, or does the valve block have to be unbolted from the chassis to give room to remove the pipes. Please, advice from anyone whose removed the pipes would be appreciated. Thank you.
jasper188
Oct 2, 2022 04:36 AM
jmayzer
May 6, 2022 10:15 PM
H Hill
Mar 31, 2021 04:53 AM
justinthorpe
Oct 8, 2014 02:26 PM
tbuckt007
Sep 21, 2010 01:44 PM
