Active Cornering Enhancement 02 disco II
Old Jan 13, 2013 | 01:10 PM
Over Rover's Avatar
Default Active Cornering Enhancement 02 disco II
I have a hole in my hose leaving from the ace pump, can I just plug it, re-fill reservoir and drive home? if resevoir is left empty, will I blow the ace pump?
thanks
Old Jan 13, 2013 | 06:53 PM
Would not want to drive empty. There is an alternate fan belt that can be used to bypass ACE I think and there are posts about it. Depending on hose with hole, might not be able to make a field patch because of pressure.
Old Jan 13, 2013 | 07:07 PM
see https://landroverforums.com/forum/ge...99/#post305990
Old Jan 13, 2013 | 08:55 PM
thanks
Go buy a new serpentine belt for your truck, get the one for the truck WITHOUT ACE, install that belt, problem solved.
Old Jan 13, 2013 | 09:27 PM
TRIARII's Avatar
AND remove your ACE parts and give them to "ME"!
Old Jan 13, 2013 | 09:35 PM
Colorado David's Avatar
If this is just a quick fix to get home, depending on how far home is, there is an enunciator light that will show up when your ACE fluid is low enough to impede operation of the system. You could always fill it up every time the light comes on IF you have a slow enough leak. You'll also wind up with hydraulic fluid all over the place that you'll need to clean up. If it's a split in the hose, skip this and go straight to replacing the serp belt.
Old Jan 14, 2013 | 10:32 AM
For a short trip, fill it, pull the ACE fuse and drive till you need to refill the fluid.
dusty1
Dec 2, 2013 04:27 PM
TheWall
Defender
May 16, 2012 05:45 AM
cfp_ivan
Dec 20, 2011 10:34 AM
Spensive
Mar 19, 2010 06:36 AM
