Adding 12v power ports
Old 04-20-2015, 03:43 PM
JCT's Avatar
JCT
JCT is offline
4wd High
I installed these on the ashtray. I wired them so they come on when the accessory is on.
Attached Thumbnails Adding 12v power ports-20150420_124846.jpg   Adding 12v power ports-20150420_124907.jpg
Old 04-20-2015, 07:19 PM
NVDiscovery's Avatar
I like that!
Old 04-21-2015, 10:36 AM
CBRacerX's Avatar
Originally Posted by fishEH
Wired these guys always hot.
Looks pretty good! What sockets did you use?
Old 04-21-2015, 08:42 PM
lighting's Avatar
Can someone have a lead of where can I buy the "USB" type of plug, really like that idea, thanks
Old 04-21-2015, 09:55 PM
Dinoco's Avatar
Amazon has them. All kinds. Sorry don't have a link.
Old 04-21-2015, 10:12 PM
Perfectphoto's Avatar
drowssap (04-22-2015)
Old 04-22-2015, 08:30 AM
Charlie_V's Avatar
Neat thread.
Old 04-22-2015, 10:43 AM
jamestfl's Avatar
ok, so for those of us not so electrically inclined, could someone walk us through an install of sockets like these? would be really helpful- thanks!
Old 04-22-2015, 03:30 PM
lighting's Avatar
Simplest way will be to look for the positive and negative leads to the existing cigarette lighter and fee your new outlet from there. Disconnect the negative side of the battery to avoid problems and run a splitter to a 10/15 amp fuse holder(I know this is already fused but can't never be too safe), from there run a wire long enough that you will be able to run 2 positives to the new outlets and run 2 negatives without the fuse holder. I like to solder and shrink wrap but I guess you can use crimp terminals, will be doing it once I get them and will post pictures if anyone is interested and I will run of a rely
Old 04-23-2015, 11:02 AM
Broken08's Avatar
This is all good...but what are you running a relay for? Nothing you can run from a lighter socket will have enough current draw to validate a relay. Relay is for big stuff like driving lights
Quick Reply: Adding 12v power ports
