adding oil cooler
Old Jan 27, 2022 | 01:59 PM
dswilly's Avatar
Originally Posted by Discorama
I used these parts in that order:
1) 2x https://products.swagelok.com/en/c/s...ion1Size:14+mm (ebay)
2) 2x https://ph.parker.com/us/en/brass-ho...ngs/126hbl-8-8 (local hose shop)
3) 1x https://www.summitracing.com/parts/sum-230806
4) 2x https://www.summitracing.com/parts/sum-220887b
5) 2x https://www.summitracing.com/parts/sum-220162b
6) 1x https://www.summitracing.com/parts/ear-502erl
The oil cooler tubing is about 0.1-0.2mm thicker than 14mm, I sanded it down until the ring of the compression ring fitted.
I have this setup for two and a half years now and no leaks or other problems.
Thanks Disco, that's great info. The trans-cooler lines have the same 14.something mm issue. I sanded them down for the PTshram connectors. Didn't know the oil cooler was the same.
Old Jan 27, 2022 | 04:13 PM
cvhyatt's Avatar
What’s the rationale for an oil cooler if you have good coolant temps from the inline thermostat? Asking for a friend. 😜
Old Jan 27, 2022 | 05:51 PM
Extinct's Avatar
Disco radiator has limited cooling capacity, about 100 degrees over ambient. Oil cooler gives you a bit more, maybe another 5-10.
Old Jan 27, 2022 | 09:48 PM
Discorama's Avatar
Oil temps are higher than coolant temps. With the oil cooler I get the oil temps down, which has undeniable advantages.
Without oil cooler: oil = 240F max, coolant = 188F
With oil cooler: oil = 220F max, coolant = 188F
Both under same conditions.
Old Jan 27, 2022 | 09:52 PM
Discorama's Avatar
The lines are are probably made from 9/16" OD tubing (14.2875mm).
I haven't found 9/16" compression fittings, no one makes them. 14mm fit perfectly with a little bit of sanding.
What are PTShram connectors?
Old Jan 28, 2022 | 07:16 AM
jastutte's Avatar
my '04 with an oil cooler and stock cooling system (refreshed a few years ago with a 180 thermostat) runs slightly cooler than my '04 with the Extinct mod.
my '04 with the mod has a waterpump and radiator that are only few years old.
Edit: to be clear, both run consistently in the the upper 180's.
Old Jan 28, 2022 | 12:55 PM
dswilly's Avatar
PT Shram is a Rover guru who has bespoke solutions for Rover issues. One is a kit for the transmission cooler connector fix. Probably oil coolers as well. He is a great guy. The connectors are similar to the Swaglok ones you used but are press-on vs compression. I use them for my trans cooler after mine blew off the originals. Work well.
P. T. Schram Rover Repair Land Rover Parts Service
Old Jan 28, 2022 | 04:09 PM
Discorama's Avatar
These would work as well, but I haven't found a source and they look expensive:
https://ph.parker.com/us/en/ermeto-d...gai14s1-2npt71
Cheaper alternative to Swagelok: https://www.fittings.space/tbc2p-014-08zm
Brass NPT female to SAE-45 for swagelok or above: https://www.discounthydraulichose.com/346-08-08.html
Old Jan 28, 2022 | 05:18 PM
dswilly's Avatar
This is the PT connector. I have message in with him on availability. It's pretty slick. He has a aviation background so it might come from that industry. You still have to sand down to 14mm but it does not compress so that could be a plus with the whimpy aluminum cooler pipes.
Old Jan 5, 2025 | 04:07 PM
Tony Luna's Avatar
Default Bumping old thread - question for Extinct
Originally Posted by Extinct
There needs to a pressure relief valve system in one of them or the flow bypasses the cooler.
How would I be able to tell if my front cover has a pressure relief valve? Brand new engine build and brand new genuine LR front cover from Rimmer Bros.
I have an OEM '02 oil cooler and lines I'm thinking about installing.
Any advice would be greatly appreciated.
Thanks!
