Adding oil cooler--questions about temperature and pressure
I've just put an Atlantic-British rebuilt short block in my 2003 D2, and I'm going to add an oil cooler to help it last a while. I've got a couple of questions for people who have done this.
As near as I can figure out, the 2003/04 are missing a "pressure relief valve" for the oil cooler on the cover plate. What the heck does that do, and what problem am I introducing if I hook a cooler up to the oil ports on the cover plate?
Also, I'm thinking about putting a fluid-control thermostat in, to let the oil get up to operating temperature before opening the oil cooler circuit. The question is, what is operating temperature? If anybody has an oil cooler and an oil temperature gauge, what kind of temps do you see under light load?
Thanks for any help you can give me.
Your front cover is compatible with the stock oil cooler lines from a 99-02. No valve issues.
Don't overthink it, install stock lines and if you can find it a 03/04 Trans cooler as the oil cooler (it's bigger). Forget the fluid valve thermostat.
I've done a few and sold the kit to forum members, plug and play.
03/04 has 2 plugs screwed in the oil cooler ports, earlier doesn't have the plugs but actual cooler lines installed.
Just to be clear, I don't have any kits, I just have coolers. The lines new are quite expensive if you can find them. I'm out of used lines.
neillr (06-09-2016)
neillr (06-09-2016)
neillr (06-09-2016)
The connection to the front cover is obviously just a pipe thread, probably 1/2-inch. The fitting at the cooler is a plastic quick-disconnect. If you want to build your own lines you will need the plug from the front cover to match a male fitting, then the actual cooler to match a female disconnect. Rover Cannibal quoted the lines, used, at $45 each but they will come down on that price. Get new O-rings for the oil cooler where the disconnects attach.
neillr (06-11-2016)
