Adjustable Panhard Rod
Old Jan 29, 2013 | 08:27 PM
coors's Avatar
Default Adjustable Panhard Rod
Now that I'm lifted I want to start sorting out my old steering components. So, I'm starting w/ an adjustable panhard rod (original one has 175,xxx miles on it) and a thought entered my mind. How do I adjust it? What am I looking for when installing/adjusting it? I have about 2.5" of lift over factory height. So, what does this mean with respect to the adjustable rod?
Old Jan 30, 2013 | 12:27 AM
jfall's Avatar
did the lift give it discovery I type of ride?
Old Jan 30, 2013 | 06:01 AM
coors's Avatar
Not following.
Old Jan 30, 2013 | 06:43 AM
drowssap's Avatar
just a silly question but shouldnt your alingment shop be making the final adjustment on your "adjustable panhard rod "
Old Jan 30, 2013 | 09:25 AM
coors's Avatar
Probably. I guess thats the answer I was looking for.
Old Jan 30, 2013 | 09:26 AM
You can not adjust the factory pan hard rod, need to buy one then adjust it so you pull the front diff back to center.
Old Jan 30, 2013 | 10:08 AM
binvanna's Avatar
You're centering the axle side-to-side with the panhard rod. As the axle moves up and down with suspension travel, it moves along the arc of the panhard rod (not straight up and down like IFS). So when it moves all the way down, it's also sort of off to one side right? Well, when you lift it, the normal ride height is now such that the axle is a little farther down the arc of travel than it was before, and therefore a little farther to the side (the driver side on a LHD vehicle). The adjustable panhard rod allows you to re-center the axle at ride-height. You can make it a little longer than stock. A lowered car would need a shorter length. It still moves in a sideways arc going up and down, but at least it will be centered when the suspension is at static height.
Old Jan 30, 2013 | 02:25 PM
coors's Avatar
Thanks for the info. Good stuff. Now, will an alignment shop know how to do this? Or is this something I can do while ibstalling the new adjustable rod? You mentioned just make it a little longer than stock? How much longer for 2.5" lift?
TOM R
Apr 2, 2015 08:08 AM
Glasshaus
Dec 24, 2014 07:01 PM
coors
May 2, 2013 01:22 PM
honda50r
Feb 15, 2013 10:47 AM
moomoo
Jun 16, 2011 08:20 PM
