Adjusting idle on 1997 Disc1
I had the same issue, the stepper motor was faulty. do you know if your stepper motor is good? I went through hell trying to find the high idle issue. I tried the jeep one and that did not work. land rover charges a $99 diagnostic fee but you will know for sure what your issue is. my local mechanic does not have a t4 computer so the only way they had to test was by pulling plugs on sensors which damaged my ecu. also, i bought an aftermarket stepper motor new and the issue with those is the computer can move the stepper motor, but can not read the position. I ended up buying a LR one and it worked fine. I actually have an oe stepper motor I am about to list on ebay that works great. 252-617-0310
youvegotwood
03-20-2010 01:50 AM
