Adventures of Irontite and the Cracked Block
Old Mar 2, 2015 | 01:32 PM
  #121
evoblade's Avatar
The pictures in the original thread aren't working for me, but it just might be blocked by job's IT department.
Old Mar 20, 2015 | 09:20 AM
  #122
pinkytoe69's Avatar
30,000 Mile Update
Down goes Frazier...
So, seems like the head gasket popped.
Details here: P306 = External HG leak? - DiscoWeb Message Boards
Note that this is the opposite bank of the original problem, so I assume it is entirely unrelated to the Irontite.
Probable course of action is to put a new gasket in the passenger side, re-torque the drivers side and cross fingers.
Old Mar 20, 2015 | 10:02 AM
  #123
drowssap's Avatar
you had nothing to loose, actually you gained 30k miles.
Old Mar 30, 2015 | 02:24 PM
  #124
pinkytoe69's Avatar
Probable final update
The block thread appears to have popped.
Tried to re-torque starting with that #1 stud. Got to almost 50 ft/lbs and then it just started turning, and turning, and turning...
Only thing happening was the stud being pulled up through the head.
Probably gonna part it out unless I can get a decent # from a craigslist buyer.
Old Mar 30, 2015 | 03:02 PM
  #125
drowssap's Avatar
I had hopes for the irontite
Old Mar 30, 2015 | 03:24 PM
  #126
ls1morethanyou's Avatar
do you know where the leak was coming from? have you torn the engine apart?
Old Mar 30, 2015 | 03:30 PM
  #127
pinkytoe69's Avatar
In fairness, I dont think this issue has anything to do with the Irontite.
Old Mar 30, 2015 | 03:32 PM
  #128
pinkytoe69's Avatar
Took off the valve cover and found the torque on the loose stud to be like 15 ft/lbs.
Tried to tighten, and when it got to about 45, it lost all torque and wouldnt regain it.
After more turns, the stud was clearly coming up out of the head.
Old Mar 31, 2015 | 02:02 PM
  #129
zski128's Avatar
Sorry to hear about your engine. Just curious, what did you originally torque the studs to when you installed? Did you do it in increments?
Thanks,
Rich
Old Mar 31, 2015 | 03:51 PM
  #130
pinkytoe69's Avatar
I went 25-50-75
