Advice?!
Old Feb 8, 2017 | 04:44 PM
  #31
disco'ed's Avatar
Default Intermittent ticking
So after a few more miles after the prislone addition... the ticking stops completely for a minute at idle then slowly gets back up to speed. Then slowed down to a tick with long pause whereas before it was rhythmic with the idle. Also stops with higher rpm,.. hoping this is an indicator of lifters freeing up? Thoughts!?
Old Feb 8, 2017 | 04:57 PM
  #32
LR03NJ's Avatar
What happened to me often? Each time I add something, all sorts of lube, additives and oil, its just a feeling that something worked. But not. Depending where you are stopped, wind direction, a diesel ford beside you, rolled up window, sound will vary but its there. Totally, you wont hear it when you are above 1700 rpm or cruising on the highway but once you start slowing down, the tick seems caught up with you and at times louder. I just really hope yours is a different tick.
Old Feb 8, 2017 | 05:18 PM
  #33
KingKoopa's Avatar
You need to be listening for the sound in your relatively quite driveway pretty much every day. It's a science experiment, keep your variables to a minimum.
If the sound is becoming more intermittent then you may be making headway, but even if it's a simple blocked lifter, it may take awhile to clean out, if it ever does.
Old Feb 8, 2017 | 05:39 PM
  #34
akrover90's Avatar
I will upload video tomorrow and see what you all think.... the mechanic is New England imports in Portland Maine supposedly works on land rovers... we'll see finding a good mechanic with motivation to get into it is hard. Thanks for all your feedback... I've learned more about engines in the pst couple weeks than In the last 36 years! Are these discos just garbage???
Ha, small world. I am also 37 and in Portland, ME. And I also have learned more about engines in the last year than in my previous 36 combined.
Old Feb 8, 2017 | 08:10 PM
  #35
disco'ed's Avatar
Nice! Have you found a good mechanic??
Old Feb 9, 2017 | 04:46 AM
  #36
shanechevelle's Avatar
If the tick is a clogged rocker in will never clear out unless you get in there and clean it out.
Charlie_V
May 28, 2017 12:18 PM
virage1
Jan 27, 2015 11:19 PM
nateandnikki
Jul 2, 2013 06:38 AM
mdburd
May 8, 2005 01:12 PM
livingetc
Nov 24, 2004 08:30 AM
