Adwest steering box issues
Hello!
I just finished up rebuilding my power steering box on my disco and I'm fairly certain I bled the system completely. I adjusted the backlash, and the Flathead bolt that tensions the bottom gear rack. When I took it for a test drive turning left seemed normal, but turning right felt as if there was no assist what so ever. I fiddled with the backlash and the Rack thrust pad and adjuster quite a bit seeing if either or both of those would fix the issue, and even rebled the system to be sure, but the problem still persists. any suggestions anyone?
