After 120K Service - Starting Problems part deux
***UPDATE*** LOW FUEL PRESSURE - After 120K Service - Starting Problems part deux
A few weeks ago, I performed a 120K service on my vehicle. Prior to the service, I had been having starting problems with my rover. While I hoped the service would help, the starting problems have persisted.
Right now, I seem to have the most trouble starting my truck in the mornings after it has been sitting over night. I always turn the key to the II position for a few seconds until I hear the fuel pump click off. Then I try to start it. Usually, it takes about 3-4 attempts to get it started in the mornings (no more than 10 seconds with the key in the start position each time). Sometimes it will sound like it is just about to turn over, but just wont catch. Other times, it may turn over but it will sputter and idle very roughly for a while (when this happens, it will either die after a few seconds or sputter for a few then run normally). There has been only one time so far that I was unable to start it.
I did change the fuel filter during my service a few weeks ago, but have not tested my fuel pressure since I have been having this problem (I don't have a guage at the moment). I do have some problems every once in a while when I am pumping gas in the truck where it triggers the automatic shutoff at the fuel station pump where it won't pump any more fuel in the vehicle like what happens when your tank fills up (this happened a few times over the past summer - and may have nothing to do with this issue). I thought it may be my vent hose clogging up or something like that, but I didn't replace it at the time and haven't had any problems with it lately.
To this point, it has yet to throw any codes. Any ideas on what may be wrong and/or the best approach to test this so I don't start throwing money away to replace perfectly good parts? Also, if it is the fuel pump, do I have to drop the tank to replace it or can I replace it throw the access panel in the cargo area?
on
This would make sense, not being caused by low coolant though.
With these codes, the ECU may not be going into open loop/ cold start cycle.
Tomorrow, chnage your starting procedure, turn the key to the second position 3 times for about 5 seconds, then attampt a start and get back to us with any change.
It is very possible that coolant temp sensor is bad, the truck is 10 years old and all.
www.atlanticbritish.com
Alright, so I reset the codes yesterday after topping up the coolant. Today, they came back after I it sputtered for a few seconds before dying (it started up the next try). Same ones: P0116 - Engine coolant temp circuit Range/Performance; P0118 - Engine coolant temp circuit high input. The temp guage in the truck has run normal and I have not noticed anything out of the ordinary regarding the performance of the truck (aside from the starting issue).
Mike, you think these codes could explain my starting issues? Is the P0118 simply the fact that the ECT is getting high resistance? How would this affect my starting? It seems that if the ECT is getting high resistance, that would mean it is sensing a cold start and the ECU would adjust to the appropriate fuel mix for cold starting.
Thanks guys.
Thanks guys.
