Aftermarket bumper affect temps?
Old Aug 5, 2012 | 04:05 PM
lr2001silver's Avatar
Banned
[QUOTE=ebg18t;335983]Yeah it is bled ok. Actually had the shop do it last time. It must be the addition of lift/ tire resistance/roof rack that is killing my highwy temps. I have replaced all of the cooling components.
Just because a shop did it does not mean if was done right
And mine has alot of mods done to it including a sd roof rack with 4 huge lights creating more resistance and my bumper lights are blocking my grill from much air flow and i still run around 194 on interstate with factory thermostat. Maybe if you want cooler temps you could look into a 180 stat and see if that helps get you what you want.
Old Aug 5, 2012 | 04:55 PM
I am going to double down on it running hot at highway speeds because it has to work to hard.
No cure for that other than slowing down or dumping the things that are making it work to hard.
So I would not worry about it.
Old Aug 5, 2012 | 05:21 PM
ebg18t's Avatar
I m running the grey soft spring thermostat. Since your till running mid 190's on the hwy this bothers me to figure out what is wrong
Old Aug 5, 2012 | 08:02 PM
DiscoRover007's Avatar
Ebgt18t your Discovery is absolutely sick
Old Aug 5, 2012 | 08:57 PM
ebg18t's Avatar
Thanks.
I know the cooling system is sick.
Old Aug 6, 2012 | 01:51 AM
Banned
Ter from
Lmao
Its possible maybe your fan clutch could be getting sick, don't freak out its not running to crazy high temps. But higher than normal Has the radiator been changed or just the rest of the coolant system? The air conditioning has a affect on the temps some times. If everything else checks out,
I have read some posts on drilling out 2 holes in the t-stat to constantly let water move threw the system. You could remove your T-stat and in the inside of it drill two holes that way water from the radiator all ways flows threw the T-stat instead of waiting until it reaches 180° to start opening. This would make the temps go down but the engine does have a certain temp range where it operates best so making the holes to big would cause it to run to cold and like $hit.
Old Aug 6, 2012 | 02:15 AM
Banned
Diagnosis of overheating in a V8 Petrol Land Rover
So you say your Land Rover overheats? In this article we’re going to cover the steps to diagnose a variety of overheating problems. Some are trivial, and others will require a complete engine overhaul. Overheating is a problem whose repair cost can range from zero to what seems like infinity.
Land Rover V8 engines are mostly aluminum with some steel and iron components. Aluminum engines are very susceptible to damage from overheating. Before we begin I need to warn you — if you haven’t been warned already — not to ever drive a Land Rover with the temp gauge in the red, not even a short distance. Driving an overheated Rover half a mile down the highway could cost you an engine.
Let’s begin our diagnosis by opening the hood and having a look. If the truck is steaming hot, leave it and return when it’s cooled off. Otherwise there’s a risk of scalding yourself. Is the fan belt in place? Is the fan tight when you wiggle it? A loose fan is a sign of a failed water pump or fan clutch.
On some Rover models it is possible to route the serpentine belt wrong, so the water pump spins backward. If your overheating follows a belt replacement check the routing.
When you look at the fan make sure none of the plastic blades are damaged. If you see any cracks or chips or broken blades, replace the fan. We have seen damaged fans explode with enough force to go right through the hood. Not only will a fan with a broken blade explode… it will also cause a heavy vibration that can ruin a good water pump in less than 100 miles.
Is there any coolant in the radiator or expansion tank? A slow leak can allow coolant to leak out until one day there’s not enough and the truck overheats. A fast leak can cause the coolant to blow out in a matter of seconds. Look for a blown hose or cracked radiator or expansion tank. Slow leaks often leave a trace of sediment where the coolant emerges and evaporates.
Slow leakage is a particular problem with the newer Discoveries, because they don’t have a warning light. And, being British, they leak.
The radiator must be filled with clean coolant of the correct type. Filthy old coolant should be flushed before proceeding with diagnosis. If the coolant is contaminated with oil you need to find the reason before proceeding. The most common cause in a Land Rover is leakage from the oil cooler into the radiator. Occasionally oil will mix with the coolant as a result of an internal engine problem but that’s rare.
Putting the wrong coolant in a late model Rover can cause overheating problems. Putting the traditional green coolant into a vehicle made for the orange Dex-Cool can result in sediment formation, and that sediment can clog the cooling system.
There are three coolants used in Land Rover products.
RTC7601 is traditional green ethylene glycol coolant. It’s used in all older Land Rover models. All Series Land Rovers, all US market Defenders, all Range Rover Classics, and all P38 Range Rovers up to 1999 use this coolant. If you have a 1999 Range Rover and you’re not sure which coolant to use… if the last digits of your VIN are YA444891 or lower, your truck uses ethylene glycol. If your VIN is higher, you should use Dex-Cool.
With the arrival of the Bosch engine management system in the Discovery II and the 1999-½ Range Rover Land Rover changed to Dex-Cool, otherwise known as OAT coolant. Land Rover stocks that coolant under part number LRN 2279. The Freelander models also use OAT.
The 2003 and newer Range Rovers use BMW’s Glysantin G48 coolant. It’s distinctive because it’s bright blue in color. Land Rover sell that as LRNG48.
If your Rover uses Dex-Cool you have to be sure to keep the system full all the time. Running the engine when low on coolant will cause damaging sediments to form.
At this point I think we should have a word on the subject of “full.” When we say “make sure the cooling system is full” what does that mean, exactly? You should make sure the radiator is full to the top, there is no air in the system, and the coolant level in the expansion tank is where it should be, looking at the level indicator molded into the tank. Air in the system can cause overheating and it can be a real problem to remove it on some trucks. Many shops use a vacuum pump to remove all the air from the cooling system before filling to avoid this situation.
If you overfill the system it will spit the excess coolant onto the ground. Don’t mistake coolant expelled from the overflow line at the expansion tank for a leak.
Anyway, once your vehicle is full of clean correct coolant we can proceed. If it does not overheat anymore after flushing your, radiator is probably mostly clogged. A like-new radiator has enough cooling capacity that the temperature gauge won’t budge from the midpoint, even on a hot summer day. If your Rover improves with flushing that means its radiator is pretty clogged and you just made it a bit better. I’d suggest you remove it and have it re-cored or replaced. If that solves your problem, congratulations, you’re done.
If your truck still overheats you’ll need to keep going. The next step should be a test to determine if your engine is really overheating. I suggest measuring the temperature of the engine with an infrared thermometer. Measure the upper radiator hose where it exits the motor as that’s near where the sender for the gauge is located. The top of the white area on your temperature gauge should be about 220 degrees on the thermometer. If your gauge is at the top and the infrared thermometer is showing 190-200 degrees you’ve got a gauge problem, not an overheating problem. If you have a real overheating problem, read on…
When the truck is warmed up feel the hoses… are they hard or soft? Soft hoses indicate a system that’s not building up pressure. Check and find the cause of pressure leakage. Some possibilities are a bad cap, leaking hoses, or cracked expansion tanks.
If the hoses are really hard that is a sign of excessive cooling system pressures. Excessive pressures often result from combustion gases leaking into the coolant passages and over-pressurizing the system.
If you find that, you should check for combustion gases in the coolant. There are two ways to do this. Auto parts jobbers sell a kit consisting of a glass tube and test liquid. You place the tube over the radiator filler hole and run the vehicle. If the liquid changes color there are combustion gases escaping through the coolant.
Another method of testing is to sniff the radiator filler with an exhaust gas analyzer. The analyzer is more likely to pick up small leaks that won’t color the test liquid.
If your truck passes both the above tests you probably do not have internal engine problems.
Overheating under load, NO combustion gas in coolant Overheating under load may be a sign that your radiator is clogged. The tubes in the radiator become lined with hard deposits as the radiator ages. These deposits will significantly reduce the radiator’s ability to remove heat from the coolant.
I suggest removing the radiator and having it checked for clogging. When you remove the radiator, look for debris blocking its surface. Also check for debris blocking the AC condenser and oil coolers. A leak from an oil cooler can leave a film of oil that collects dust like a magnet, leading to complete air blockage of large parts of the radiator. If air flow is restricted the vehicle will overheat under load.
You should also check the engine driven fan if you have one. It has a viscous coupling that allows it to freewheel in cold weather and be tightly coupled in hot weather. If the fan freewheels on a hot day it won’t cool adequately.
The electric fans are controlled by temperature and/or AC operation. In some cases the fans are turned on whenever the air conditioner is running. In other cases the fans come on when a threshold engine temperature is reached. In either case the electric fans need to work to keep the motor cool in summer.
In a few cases we have seen overheating caused by separation of the water pump impeller from the shaft. This is more of an issue with BMW and Jaguar cars that use plastic impellers pressed onto a steel shaft. The only way to check this is by removing the pump.
Here are some other causes of overheating that you should check:
If the radiator cap is bad (not holding pressure) or if the cooling system has other air leaks the cooling system will boil and overheat. A stuck thermostat will cause overheating all the time (stuck closed) or cold running all the time (stuck open.) A Rover may overheat in hot weather if the fan shroud is missing or damaged. A clogged catalytic converter will cause substantial heat buildup under the hood and can lead to overheating and serious loss of power.
Overheating under load, combustion gas in coolant If you have combustion gas in the coolant your motor has one of three problems:
One of the head gaskets has failed; One of the heads, a cylinder liner, or the block has cracked; Or one of the cylinder liners in the block has moved.
In some cases you may see steam and smell a sweet odor from the exhaust. That’s a sure sign of coolant entering the combustion chamber and exiting via the tailpipe. Much of the time, though, the leak goes the other way — combustion gases going into the coolant, and there may be no visible evidence.
The first step in finding out what went wrong is to remove the cylinder heads. When you do this you’ll have a chance to check for sludge under the valve covers and intake. If you have a lot of sludge I suggest engine removal and a complete teardown and cleaning. If the engine is sludge-free you may or may not be able to repair it in the car, depending upon what you find.
The head gaskets should be examined carefully. You may see tracks where gas leaked from the combustion chamber to a coolant gallery. Tiny cranks in the ring that seals the combustion chamber are a sign of pre-ignition. You can check for localized overheating by measuring the gasket thickness. A spot that ran hot will have a thinner gasket – something you can pick up with comparative micrometer measurements. An experienced machinist will be able to spot many head gasket failures.
Failed head gaskets are the most common reason for combustion gases getting into the coolant. But it’s important to understand that you can’t fix a head gasket failure by just slapping on a new gasket and bolting it together. Doing so will usually result in a repeat failure at some future date. You need to find and fix the underlying problem. That means repairing mating surfaces that are not perfectly flat, repairing the cause of the pre-ignition, or fixing the cause of localized overheating. Localized overheating is often a result of injector or ignition troubles on one cylinder and it can be difficult to find but it’s an insidious killer. Left alone it will overheat a single cylinder until the liner loosens in the block and even greater damage ensues.
The heads are checked for flatness with a straightedge. Aluminum heads should be flat within .002 inch. They are checked for cracks by applying air pressure while bolted to a jig, or by application of liquid crack detection chemicals that highlight cracks under black light. Cracked heads can usually be repaired by welding. Warped heads can be surfaced on a milling machine or specialized cutter. Rover heads should not be surfaced more than five thousandths of an inch, because the compression ratio increases as the heads are shaved.
If coolant was entering the combustion chamber you will see one or more cylinders scoured spotlessly clean by the steam. Pay particular attention to those cylinders if you see them because they are the ones that have failed. If you see this, or if you see milky oil in the engine, you should pull the oil pan and check for lower end damage because coolant is getting into the oil. Coolant mixed with oil will damage bearings.
The steel cylinder liners are pressed into the block and milled flush with the top. If you see any liners that have moved downward that’s s a sure sign of failure. If you do not see any signs of movement in the liners you must make a decision to remove and test the block or take your chances and refit the heads.
The block is tested by bolting plates over the cylinder head mating surfaces and applying pressure to the oil and coolant galleries to check for leaks. Leakage indicates a loose liner or the presence of a crack.
The block can also be checked for flatness on the cylinder head mating surface. As with the head, the surface must be flat within .002 inch. I have seen a number of instances where shops replaced head gaskets, experienced a subsequent failure, and assumed the block had a bad liner when in fact the deck surface was warped. It’s important to figure out what went wrong if you are to have a lasting repair.
A block with a dropped liner can be repaired by removing the liner and pressing in a slightly larger replacement that is flanged at the top so it can’t move. A block whose cylinder head mating surfaces have warped can be surfaced in a process called decking. If the cylinder head mating surface has warped, there is a good chance the crankshaft bore is warped also. In that case, the block will need the main bearing journals line bored after it’s been decked.
The traditional method of fixing liner and deck problems in Rovers was to replace the engine block. With the increased costs for new blocks repair is now becoming a better option.
I hope the tips in the article above will allow you to diagnose your overheating trouble. In the case of engines with combustion gases in the coolant there is usually some other problem that led to the internal engine failure. Before you count the job done you should find that problem and fix it.
Old Aug 6, 2012 | 03:41 AM
Wow that's a mouthful.
1. If overheating or running warm at highway speed, the AC condenser fans and the viscous drive fan have very little to do with this, unless running backwards (belt route or blades reversed). Example - try holding a large pizza box out the window while moving at 60 mph.
2. If all cooling components changed, if this was done over a period of time, trash from the repair work could be lodged in the metering holes that are already existing in your thermostat. These allow a sample of the hot coolant to mix inside the thermostat and make it open. Because the stat is remote (not inside the block) there can be a delay in it operating. More trash, slower operation. Even with a stock stat it is fully open at 204F, and once stat is well above "all the way open temp" it won't cycle on/off. So coolant spends less time in the radiator. So radiator better be clean, inside and out. Three inches of dried mud in the fins from wading may need to be washed and blown out, and all the leaves between AC condenser and main radiator removed. The grey 82 C stat is certainly an improvement.
3. We have had reports of belt slip caused by too much degreaser on engine bay. This also showed up as low output from alternator.
4. If replacing water pump, consider an aftermarket model with larger bronze impeller. And do viscous clutch at same time, they are in a "death spiral" relationship. Water pump is rated for about 2.5 gallons per minute at 1000 rpm, so you can test it into a 5 gallon pail. Usually missing impeller blades make pump vibrate and wobble.
5. The previous article is older, and there is no way you should be using Dexcool except as mouthwash for the sales department.
6. Spike is also right, if you increase the load on the engine, temp will go up, so if trailering or rock crawling or honkin' big tires need to be sure cooling system is in tip top shape. While it is not a disaster yet, it is headed in the wrong direction. It still should be cool rolling down the highway.
7. As for drilling holes in stats, that is for the "conventional" in the block style. A small 1/8 inch hole is placed at the 12:00 position so bubbles in coolant don't form a steam pocket and throw stat out of the normal operating range. Modern stats have a "jiggle" device or a ball bearing as a valve, this allows the gas to pass and then be blocked off by pressure from the other side. The D2 has a remote stat, with holes already. Some D2s also monitor for stat being stuck open, some users with D2 and in-line stat conversion found out that too many bypass holes threw a code.
Attached Thumbnails Aftermarket bumper affect temps?-land%252520rover%252520thermostat%252520005.jpg   Aftermarket bumper affect temps?-d2-stat-internal.jpg   Aftermarket bumper affect temps?-d2-stat-internal-2.jpg   Aftermarket bumper affect temps?-land_range_rover_classic_discovery_defender_oem_water_pump_g.jpg   Aftermarket bumper affect temps?-p1030596.jpg
Old Aug 6, 2012 | 06:16 AM
ebg18t's Avatar
The water pump was replaced in march when the head gaskets were replaced, oil pump gear was replaced at the same time. Radiator, thermostat were replaced 3 weeks ago.
I am only running 33" tires, so not 'honking' by any means.
Old Aug 6, 2012 | 07:04 AM
Well, with all that work - maybe a fan blade is on backwards or a belt is routed wrong. At idle, should suck a paper towel to grille, not blow it away. If thermostat was not oem that might be an issue. If you have the 82 C grey "soft spring stat" it certainly should not be running "warm" like above 200 F on high way.
My old D1 with 180K plus and a 180 stat does 180-183 on highway, maybe 187 if 70 on a hot day. Stock tires. Different rad, same water pump.
Also, could be your coolant temp sensor reads different than the next guys. It is not too expensive, but it can also be removed and the calcium polished off of it with emery paper. If it has too much calcium, that could act like an insulator and slow heat response to your gauge (assumes scanner or ultra gauge) - if using an IR thermometer you will get various readngs and exact repeatability is an issue.
