Aftermarket Bumper(s): do I need to adjust suspension?
Old Aug 2, 2012 | 11:10 PM
00Balls's Avatar
Default Aftermarket Bumper(s): do I need to adjust suspension?
I'm thinking of installing an ARB bumper on my '02 DII and I was wondering if I need to account for the extra weight of the bumper? Also, If anyone out there has another suggestion for an aftermarket bumper, I am open to ideas. I don't necessarily need the brush gaurd (and associated weight) that the only ARB that fits an '02 has.
Thanx for your help in advance!
Old Aug 2, 2012 | 11:21 PM
jafir's Avatar
You might be ok with just the bumper. I know when I put the ARB bumper and winch on my 03, I noticed it. I am much happier now that I have a lift.... but that's also because I wanted a lift.
Old Aug 2, 2012 | 11:49 PM
00Balls's Avatar
Did you notice a difference in your front end height or drivability?
Old Aug 3, 2012 | 12:03 AM
oilspotLR's Avatar
I think you should go with new medium springs. You don't have to replace the shocks if you don't want to in theory.
Old Aug 3, 2012 | 06:17 AM
ebg18t's Avatar
If you are still on stock suspension you will likely need stiffer springs. Otherwise you are going to sag some.
Old Aug 3, 2012 | 08:21 PM
I put a ARB on my truck just over a year ago, I still have the stock suspension and my truck still sits level.
The ONLY problem I have is in the snow/rain when I am below half a tank of gas the back of the truck will get alittle squirrely.
But it is ONLY on slick roads and with less than half a tank of gas (less weight in the back) so I just dont let it get below half a tank when it rains.
Old Aug 3, 2012 | 08:30 PM
At 118K, you have a tired suspension that has settled about 1.5" since new.
So depending on the type of wheeling you do, if you want a better ride with more control. nes shocks and coils would be a huge plus.
Old Aug 4, 2012 | 08:32 AM
00Balls's Avatar
Thanks for the input fellas!
Old Aug 4, 2012 | 08:39 AM
jafir's Avatar
Yeah. I thought I was nose down. Now I didn't actually measure it before, so I'm not sure how much. Could have been just half an inch, could have been 2.
Old Aug 4, 2012 | 04:57 PM
I measured mine before and after, same height.
