Aftermarket stereo install
I was curious if anyone has had luck with keeping the steering wheel controls after changing the stereo? If so what wiring kit did you use? Is there a kit that also includes the amp bypass? Thanks for any help, I’ve looked and found a kit on EBay but I had a lot of trouble using it in another vehicle. SWI-CP2 Universal Steering Wheel Control
there are a number of threads here on the forum. Lots of people have done it, mostly with joying halo style head units. You can get an adapter on amazon.
mollusc (07-19-2021)
some here have had luck some have not.
my volume up works but not volume down. Other buttons work
PAC SWI-CP2
Metra 70-1784 harness adapter
If you wire those two items into whatever wiring comes with your head unit and it should retain all controls - the SWI-CP2 needs to be programmed to recognize your steering wheel buttons but it is straight forward compared to other electrical circumstances with LR.
I was able to do this in my p38 without cutting the factory harness.
Broken08
Audio/Visual Electronics
04-12-2015 07:21 PM
VB_Rover
10-19-2005 12:25 AM
