Aftermarket stereo install
Old Jul 18, 2021 | 11:43 AM
me 2's Avatar
Default Aftermarket stereo install
I was curious if anyone has had luck with keeping the steering wheel controls after changing the stereo? If so what wiring kit did you use? Is there a kit that also includes the amp bypass? Thanks for any help, I’ve looked and found a kit on EBay but I had a lot of trouble using it in another vehicle. SWI-CP2 Universal Steering Wheel Control
Old Jul 18, 2021 | 08:52 PM
tnrangerover's Avatar
there are a number of threads here on the forum. Lots of people have done it, mostly with joying halo style head units. You can get an adapter on amazon.
Old Jul 18, 2021 | 08:56 PM
redwhitekat's Avatar
some here have had luck some have not.
my volume up works but not volume down. Other buttons work
Old Jul 19, 2021 | 06:56 AM
mollusc's Avatar
Android-based head units can use the existing controls without an adapter. As stated, there are plenty of threads on here that answer these questions.
Old Aug 4, 2021 | 04:10 PM
ForgamereOsterreich's Avatar
PAC SWI-CP2
Metra 70-1784 harness adapter
If you wire those two items into whatever wiring comes with your head unit and it should retain all controls - the SWI-CP2 needs to be programmed to recognize your steering wheel buttons but it is straight forward compared to other electrical circumstances with LR.
I was able to do this in my p38 without cutting the factory harness.
Old Aug 4, 2021 | 10:47 PM
Sw1 cp2. How do you program that
Old Aug 5, 2021 | 11:11 PM
sayeedA
Feb 1, 2019 07:55 PM
Broken08
Audio/Visual Electronics
Apr 12, 2015 07:21 PM
ben.jammin0011
Aug 4, 2010 06:15 AM
WGM
Apr 14, 2007 10:32 AM
VB_Rover
Oct 19, 2005 12:25 AM
