Aftermarket stereo mounting bracket
Old 12-27-2023 | 10:34 PM
ReignRock's Avatar
Default Aftermarket stereo mounting bracket
Anyone have a link where I can get a mounting bracket for a single din aftermarket stereo. It’s going in a 2004 Disco 2.
Old 12-28-2023 | 01:02 AM
mollusc's Avatar
The hole in the console is single-DIN. Your new head unit should come with a sleeve that will fit right in.
Old 12-28-2023 | 11:07 AM
longtallsally's Avatar
To add, installation will be greatly eased by removing the entire center stack.
from my last installation:
In the second pic, you’ll the bracket from this pic below with it still installed.
I left that bracket in my first Disco when I did a head unit, but found if I removed it in the second and 3rd ones that there is WAY more space. Otherwise, if you are using a transition harness like I am from Crutchfield, the wiring gets really tight and difficult and introduces the risk of pinching a wire or the like. It takes a good bit more time to do all this, but it ends up WAY cleaner and is quite reversible.
Old 12-29-2023 | 12:50 PM
ReignRock's Avatar
Thank you for the response. Another question: I’ve found two different wiring harnesses for the Disco 2. Is there a way to know which one would be in my 04 SE without removing the factory stereo first?
YETIX
02-01-2023 11:05 PM
ononomos
02-12-2021 03:21 PM
velija
09-23-2015 10:50 PM
ben.jammin0011
08-04-2010 06:15 AM
cathaan
Audio/Visual Electronics
11-20-2006 12:31 PM
Quick Reply: Aftermarket stereo mounting bracket
