Aftermarket stereo question
FIRST POST
I want to buy an 11 inch touch screen stereo that I found on amazon, which is single din and should fit my 2000 disco II . However, I went on crutchfields website and looked at their single din stereos and they said that some of them would fit and some of them wouldnt so why would some single dins fit and then ither single dins will not? That makes me scared to buy the one off of amazon and risk it not fiiting. ( Its not available on crutchfield ) any help would be great thanks
FIRST POST
FIRST POST
bballjames
here are the two head unites ( single din ) that I am wanting to order
they are all single din but im needing to be sure that they will work. I realize that their all of brands but I have had them in previous vehicles and havent had a problem
Amazon.com: Absolute AVH-1100BT 11-Inch TFT LCD Motorized Monitor Digital Video Multimedia Player with Touch Screen System and Built-In Bluetooth: Electronics
or
Amazon.com: Pyle PLD10BT 10.1-Inch Motorized Touchscreen Bluetooth Receiver Multimedia System with Built-In DVD Player: Electronics
or even this onethey are all single din but im needing to be sure that they will work. I realize that their all of brands but I have had them in previous vehicles and havent had a problem
bballjames
or
or even this one
Amazon.com: POWER ACOUSTIK PD-931NB 9.3" INTEQ LCD TOUCHSCREEN MULTIMEDIA RECEIVER WITH BLUETOOTH(R) & DETACHA: Car Electronics
or
or even this one
I think drowssap is right about questioning the hookup. I don't think physically fitting is the issue. As long as they are single din there should be no issues. There is a good amount of space back there. I couldn't see any description of output connections. I would call crutchfield. They are usually pretty knowledgeable and could probably tell you why their site lists them as "not able to fit". You will most likely need a conversion harness if you are planning on using factory amp. If not using the factory amp, plan on running speaker wire from the head unit to under the driver's seat (where the factory amp is), and manually connecting the speakers. If using an aftermarket amp/speakers, plan on rewiring everything.
autooracle
02-09-2007 05:51 AM
