Age Old O2 Sensor Questions.
Old Sep 22, 2021 | 11:49 AM
RoverSE7's Avatar
Default Age Old O2 Sensor Questions.
Sorry to post a question about something that maybe covered here before...
I was considering changing all my O2 sensors when a few months ago I had couple O2 codes that I read through my own scanner and so I said "heck I'll just change them all out and hopefully my CEL would go out..." But I'm not sure that having no circuit activity that just changing them all out would even have any effect? What would cause this circuit non activity? This print out I got from my shop that was going to help me out and change them out for me but he ran out of time to figure out why there was no circuit activity? And frankly I don't want to keep paying them to keep trouble shooting. Has this been an issue for anyone and what was the remedy for it? And second, my passenger catalytic converter my mechanic says is rattling inside. I have noticed that when I start the truck it does make a louder exhaust rattle sound almost as if a tinny sound but seems to quiet down after a few minutes warm up. It is still there after warms up but much quieter. Any thoughts if the Cats are just simply bad and is causing the trouble codes? I planned only eventually changing out the exhaust from Cats back but now it seems I may "have" to replace the entire exhaust as I won't be able to pass NYS Emissions test as it stands right now. Hey thanks guys for any input you may have on these codes and my Cat rattle.
O2 codes: no circuit activity?😳
Old Sep 22, 2021 | 02:46 PM
redwhitekat's Avatar
They are cheap at rock auto
inspect wiring
replace all o2 sensors
replace your fuel purge valve
pcv mod
tune up wouldn’t hurt plugs wires etc
all cheap stuff.
if you get shop to do it. Not so cheap
Old Sep 22, 2021 | 03:00 PM
RoverSE7's Avatar
inspect wiring
pcv mod
all cheap stuff.
I will go for it! And then see what the out come and post back here. Thanks.
Old Sep 22, 2021 | 04:03 PM
RoverSE7's Avatar
inspect wiring
pcv mod
all cheap stuff.
Hey Question which brand do you recommend?
Old Sep 22, 2021 | 04:44 PM
RoverSE7's Avatar
inspect wiring
pcv mod
all cheap stuff.
Hey Sorry is what is the PVC Mod? and location? As well the Fuel Purge Valve? Is that the unit located under passenger side frame rail is it not? i cant find any reference in PDF search for either of these terms in the Rave
Old Sep 22, 2021 | 05:26 PM
andino's Avatar
PCV mod can be found here: https://landroverforums.com/forum/di...-install-92942
Old Sep 23, 2021 | 06:24 AM
RoverSE7's Avatar
Originally Posted by andino
Awesome Thank! I just purchased the PCV valve from Napa from the link someone gave in that thread. Thanks again. Oh and what about the fuel purge valve, where do i find that? Tried searching in the forum also You would think it would search and highlight the thread but i could not find it. TIA
dswilly
Aug 27, 2021 05:44 PM
sonic242
Sep 10, 2015 08:35 PM
PNW Disco
Aug 11, 2014 02:51 PM
me 2
Aug 1, 2012 10:51 AM
Pauldf
May 17, 2012 05:03 PM
