Air bag question
Old Mar 12, 2013 | 10:55 AM
kfx4001442's Avatar
Nice! Wonder if they'd be cheaper @ 10% off from them or @ 20% off from Advance Autos website.
Old Mar 13, 2013 | 06:55 AM
acamato's Avatar
Originally Posted by kfx4001442
There was a 20% off total order coupon code on Advance Auto's website yesterday while I was tooling around looking for my parts to rebuild my drive shafts. Would've been nice had they had all the parts to do so.
TRT41 - $40 off order over $100.
ACCESS124 - $10 off orders over $30
$25 off orders over $70
$40 off orders over $110
Place two separate orders for airbags and save $80 and get free shipping & pay $107.99 each
Old Mar 15, 2013 | 07:28 PM
KlamathMatt's Avatar
Default Best way to depressurize rear air bags?
I got the arnott bags and was looking in rave and it suggest to depressurize using test book. Is there another way to do this, and how do you know if its been depressurized enough?
Thx
Matt
Old Mar 15, 2013 | 09:48 PM
wreckdiver1321's Avatar
Thx
Matt
Crawl under the driver's side of the truck, right under the driver's door, with a big flat head screwdriver and a 10mm wrench. You'll see a black plastic box. Use the screwdriver to undo the two fasteners and remove the cover.
At the front of the compressor assembly (the part closest to the front) you should see three black air lines going into a block that are held on by brass fittings. It should look like this:
What you want to do is use the 10mm to loosen, but not remove, the two outside fittings.
If you take them out, it will be a bugger to get them back into place and they may not seal. Leave the middle fitting alone. Just loosen the left and right fittings. You'll hear the air start to hiss out and eventually the air springs will depressurize.
Old Mar 16, 2013 | 09:06 AM
acamato's Avatar
Since I knew that I was going to throw out my old airbags. I just kept a door open to prevent the SLS from trying to level the DII. I poked a hold in the air bag with an utility knife.
If you want to save your old airbags do what wreckdiver said to do.
Old Mar 16, 2013 | 12:22 PM
Default Air bags depressurize
Thanks, guys. I like the puncture with a knife approach -- sometimes there is an obvious solution saring right at you. Though, wrekdriver, i liked your write up and will save up to do that lift with the airsprings....didnt think spacers could cost that much but if they are precisley machined that would make all the difference.
Thanks again,
Matt
Old Mar 16, 2013 | 01:02 PM
Thanks again,
Matt
Thanks for looking!
Keep in mind the spacers I used are much more expensive than the ones I recommended. If you order the ToddCo kit from Lucky8, you'd only pay $118.
The reason I did mine like this is I kept one of the springs as a spare in case of a puncture. That way, I can fit a new one when I'm on the trail if I have to.
jdwilks
Feb 3, 2013 10:42 AM
catchthebig1
Sep 24, 2010 11:57 AM
rphotographer
Jan 26, 2009 01:56 PM
hector5016
Nov 23, 2005 09:21 PM
scobie
Oct 19, 2005 12:42 AM
