Air Bags Stink
Old Aug 21, 2008 | 08:01 PM
timelessride's Avatar
Default Air Bags Stink
Well I finally figured out my airbag problem. My Right rear Airbag would deflate it self from time to time mostly when i would park and shut the rover off. The past few days it would do it while driving if there was more than my self in the truck.so tonight I climbed under and sprayed soapy water everywhere to find that the bag it self is leaking. I also noticed that the air pump did not stay running? the truck was sitting on the bump stop shouldnt the pump have tried to keep it up? so my real question is does any one know where and about how much I can get a new bag from? I am in the central NJ area.
Thanks
Tim
Old Aug 21, 2008 | 08:08 PM
Default RE: Air Bags Stink
Oh yea I guess it would help if I told you guys its a 2000 Disco 2 with 120,000 miles on it
Old Aug 21, 2008 | 08:31 PM
http://www.roverparts.com/Parts/RQG100041.cfm
http://www.roverparts.com/Parts/RKB101200G.cfm
http://www.roverparts.com/Parts/9268D2ABP.cfm
Here are your options, fix it now, and again later, or fix it once and for all.
Old Aug 21, 2008 | 08:40 PM
If I pull the bags. there is obvously things that need to be unhooked ie. the Air Compressor? the directions that are listed with the conversion kit they will tell me how to do that?
does taking the bags out screw up anything else?
Old Aug 21, 2008 | 08:45 PM
All very good questions. No it will not screw anything else up
There are good directions at www.discoweb.org, click the tech link and scroll down and find the "D2 air to coil conversion" link.
I do not know if the coil kit comes with instructions or not, I would assume that they do.
Old Aug 21, 2008 | 09:57 PM
Jupiter Rover's Avatar
You will love springs.
Good luck with the conversion!
Old Aug 21, 2008 | 10:10 PM
Thanks Guys
I will let you know how I make out
Tim
Old Aug 22, 2008 | 09:40 AM
ORIGINAL: timelessride
Thanks Guys
Tim
The SLS is easy to fix if you want some help, don't jump into springs if the system can be fixed. New bags are cheap and the rest is a walk in the park.
Old Aug 22, 2008 | 10:21 AM
Urban Panzer's Avatar
Agree with Mike, KEEP the air imo!!!
greg409
Feb 23, 2012 04:47 PM
DiscoIIBrandon
May 6, 2011 08:23 AM
van1
Jan 13, 2009 04:11 PM
tripz
Jan 4, 2007 05:58 PM
tripz
Feb 7, 2006 06:03 PM
