Air to Coil Conversion with pics!
My first impressions were a slightly stiffer/stable ride than my previously worn out set up. I do notice a slight "sway" on the highway but it corner's like a champ. I don't have close access to test out the off-road capabilities, but I found a couple of unpaved and pot-hole riddened alley's to zoom up and down. I was very impressed with the responsiveness of the set-up. I need more time behind the wheel before releasing my true review.
Overall, very pleased w/ the TF MD kit.
Found a few more pictures, so may as well post them. Here we are putting the passenger side back together, and its coming along pretty smoothly, but if you notice, someone took apart the sway bay connector and just kind of let it sit there! DOH! Dont worry, it reconnected pretty easy!
And here is a good photo illustrating what I meant my lining up the holes for the front suspension:
I have a hawkeye which I used to reprogram the SLABS computer.
I don't think so, but it will help keep from running your battery down. (assuming you disconnect the correct connector.)
