Air Condition blowing hot air
Old Jul 22, 2009 | 09:07 PM
slexum's Avatar
5th Gear
Post Air Condition blowing hot air
What's up guys? I have a 2002 Discovery series II, the air conditioning is only blowing cold out of the two drivers side vents, it blows normal air through the passnger side vents and extremely hot air into the floor vents. Any idea why this may be happening?
Thanks, Shannon
Old Jul 22, 2009 | 09:21 PM
lipadj46's Avatar
First check your freon level and add a pound if needed. If not then it could be your blend flap motors or servos are bad.
Old Jul 23, 2009 | 01:51 AM
Urban Panzer's Avatar
common problem and a result of low gas pressure.
Old Jul 23, 2009 | 07:18 AM
If you are blowing cold from one area and not the other, you have freon, I would agree with the the other reply, bad servo or blend door issue.
Old Jul 23, 2009 | 10:14 AM
slexum's Avatar
5th Gear
Hey thanks allot, I'm going to call around and see what kins of a cost I'm looking at here.
Old Jul 23, 2009 | 10:35 AM
Mine did this recently, cold from one side and just normal temp from the other, I to suspected the mix flaps in the heaterbox, and after LOTS of messing with them, determined there was nothing wrong.........consequently found out I had a leak in the aircon system, a new pipe was needed, re-gassed and now 100% cold from both sides.
I don't know how or why it goes like that..........and it certainly leads the brain to think along the lines of mix valves etc, but IMO it is HIGHLY unlikely it is a flap / valve in the heater box.
Old Jul 23, 2009 | 11:13 AM
Good information, as with you, doesn't make sense but for whatever reason, it worked for you, that is the bottom line we are all looking for.
Old Jul 23, 2009 | 02:43 PM
lipadj46's Avatar
How about this, I had a fast leak (losing a pound in a couple days). I kept adding a pound of the R134a with the leak stop in it but it just kept leaking. So I gave up and stopped using my AC until I had a chance to trouble shoot. Came back a month or so later put a pound of refrigerant with UV dye and that was 2 weeks ago and my AC is still blowing cold and holding the pressure but the compressor was a bit loud. I put a can of oil in and everything is quiet as can be now.
Fingers crossed but it seems that the leak guard needed some time to marinate or set, who knows.
squealpigs
Sep 2, 2014 09:06 AM
haleyrover
Aug 29, 2011 06:20 AM
dammad
May 24, 2008 07:16 PM
