Headrest monitor's
Old Jul 21, 2009 | 08:44 PM
thomas22's Avatar
Angry Headrest monitor's
The Problem I'm having is I installed one in dash 7" Touchscreen In my land rover disco 2 Everything has been working fine with it. So i went ahead and installed 2 headrest monitors for the kids. now When the engine is running the monitors Have white horizontal lines running through the headrest screen but go away when the engine is off i have tried to run a wire straight to the battery and to the monitors and they worked fine but i cant have them like that or it will drain my battery best buy told me either Ground loop wire or a CAR video distribution amplifier any ideas?
Old Jul 22, 2009 | 03:17 AM
Rover Chris's Avatar
I would agree with best buy, you are most likely having a ground loop and either a video filter or a good video amplifier (which should have a filter in it), also may want to re-tap all your grounds and get them as close to the video source unit as possible.
Old Jul 22, 2009 | 03:36 AM
stevemaclaren's Avatar
7th Gear
you don't need the apostrophe in the word monitors. plurals do not require apostrophes.
Old Jul 22, 2009 | 07:51 AM
jycsalas's Avatar
r u seerius? r u gona goe aroun fix'n peepols gramtical errers?
giv addvise or help on his isshoe, nott his engrish.
Old Jul 22, 2009 | 02:54 PM
thomas22's Avatar
Wink
Sorry about the english had a little to much to drink last night was trying to write with the screen spinning Thanks i will try the ground loop wire first
Old Jul 23, 2009 | 05:16 PM
salve7's Avatar
Close one eye and prop your forehead on the monitor if it happens again!LOL
Manny735
May 19, 2010 01:45 PM
Manny735
Audio/Visual Electronics
May 14, 2010 09:18 PM
mrgeemoney
LR2
Jan 9, 2009 02:46 AM
allstarmac08
Oct 10, 2008 02:03 PM
Doak
Nov 20, 2006 09:46 AM
