air filter
Old Feb 17, 2007 | 05:04 PM
tbriska's Avatar
Default air filter
Does anyone know if it alright to use a K&H air filter in a disco 2. I was told not to use them because it will trip sensors. Is this true.
Old Feb 17, 2007 | 08:46 PM
Default RE: air filter
Do not use a K&N in a D2, you will contaminate the MAF for $125. Stay with a paper filter.
Mike
Old Feb 18, 2007 | 01:20 PM
Darover's Avatar
I'm new to Rovers myself, but I have a feeling that the MAF problem thatis blamed onthe use of K&N air filters, has to do to the over oiling of the filters. Or, has it ever happened to D2 owners before the first maintenance of the filter. If so,that would contredict my thoughts.
Old Feb 18, 2007 | 02:06 PM
It is a pretty common problem when being run on Rovers. No matter how carefull I was with the cleaning and reoiling of my K&N, it cost me 2 MAF's over 2 years.
Mike
Old Feb 19, 2007 | 12:19 AM
bookerbr's Avatar
What about an amsoil air filter?
Old Feb 19, 2007 | 10:43 AM
ORIGINAL: bookerbr
I don't know anything about the Amsoil air filter, can you get us some more information?
Mike
Old Feb 19, 2007 | 12:06 PM
Darover's Avatar
well, didn't want to take a chance and removedmine that had been on my D2 for only 3 weeks.
Old Feb 19, 2007 | 12:49 PM
bookerbr's Avatar
Well, on the amsoil webpage I found some info. They use WIX air filters and here is the little write up on it.
In the last two years, AMSOIL has introduced more new products and made more technical advances than during any other period in the company’s storied 33-year history. AMSOIL now provides engine oils for nearly every application, multiple gear oils, greases, fuel additives and appearance products. To offer a more wellrounded selection of automotive products, AMSOIL also offers high quality
products from other manufacturers such as BOSCH. Recently, AMSOIL’s focus has been on the filtration market. The recently launched Ea Filter line includes the finest filtration products in the world for the auto/light truck market, and Donaldson covers the heavy-duty market. To complement the Ea line of filters, AMSOIL now offers WIX filters, allowing one-stop shopping for automotive customers. AMSOIL will carry over 700 WIX air, oil, fuel, racing and transmission filters for automotive and light truck applications.
A History of Excellence
WIX is well-known around the world for its innovative filtration products for the automotive and light truck market. Founded in 1939, the Gastonia, N.C., company
earned acclaim during World War II when it created an oil filter out of a paper tube, wooden plugs and yarn when steel was in short supply. In 1954 WIX created the revolutionary spin-on oil filter that was eventually adopted as original equipment on most vehicles.
Today WIX manufactures some of the best air, lube, cabin air, fuel crank case breather and transmission filtration products on the market. The company is also widely known for its support of NASCAR.
Superior Construction
WIX oil filters have a full metal base plate for superior strength at the double seal. They also feature a silicone anti-drainback valve that stays flexible in extreme temperatures. This improves oil flow and keeps oil in the filter to prevent dry starts.
WIX oil filters use an up-front by-pass valve. This design is superior to top-mounted valves because it helps to keep oil from washing past dirty media and entering the engine. The glass-enhanced media in WIX oil filters offers greater efficiency, capturing more 10 to 12 micron sized particles than other cellulose/synthetic blend medias. They also have a coil steel spring to ensure internal filter parts are sealed properly.
WIX panel element air filters have a linear path through the filter for low airflow restriction, a specially formulated adhesive to form WIX’s exclusive pocket pleat for the filter media and a soft sealing urethane gasket molded in place on the filter element.
Radial air filters are constructed of mesh screen on the inside wall diameter for element strength and media protection from backfire. Each round filter is manufactured with heat-resistant plastisol with specially designed crush seals on the top and bottom walls and adhesive seal joining the media ends. Additional Filtration Products AMSOIL offers WIX filtration products for auto/light truck and racing applications. This includes not only standard air and oil filters, but fuel, transmission, cabin air and filters specially designed for racing as well.
fuel
Dec 13, 2004 04:49 PM
