air filter housing clips broke
Old Sep 20, 2009 | 11:21 PM
tsuami1's Avatar
Default air filter housing clips broke
I'm getting pretty crappy mileage- about 9-10 mpg city- in my '04 w/ 75k miles. I know I need to flush and refill everything, clean intake and induction, replace spark plugs and wires, and poss. replace the 02 sensors- but might my air filter dirtiness and lack of tight seal coming from 2 broken clips at the round intake connection be a significant part of it?
Are other people having these semi-flimsy clips break? I know the housing still stays in place thanks to the relatively tight fit of everything but does this system rely on a vacuum tight seal?
Also how do you tell if you filter is bad? I held it up to sunlight and I could see little slivers of light but not much. Color-wise it still looks pretty orange (LR factory filter) and not too dirty
Old Sep 21, 2009 | 02:10 PM
How long has it been in there?
10,000, 20,000, 50,000 miles?
If it has been 20k or more change it.
From the sounds of it it needs it anyway.
$12 at Advance Auto for a Purolator air filter.
If you had a leak past the filter box it would set off the check engine light.
The break all the time and replacements are hard to come by because of this.
You may be stuck buying a brand new one.
But check these places first.
www.autosportsunlimited.com
www.roverlandparts.com
nehi1429
May 21, 2015 09:28 PM
70gsrick
Mar 16, 2012 12:06 PM
Antmen
Jun 16, 2010 02:52 PM
rvrguy
Jun 15, 2008 07:19 PM
mrjcrew
Apr 29, 2008 09:09 PM
