03 with flashing oil light
Old Sep 21, 2009 | 02:14 PM
shonuff93's Avatar
Default 03 with flashing oil light
My 03 disco with 94000 miles just recently started to flicker its oil light at me at hot idle. No engine noises or leaks. I'm going to change the oil pump, and I was wondering if anybody had an opinion on rebuilt pumps and their durability. I like the price alot more. Also was wondering if its possible to have a bad pressure sensor and if there is anyway to test it myself. One more thing, I want to get the oil pressure tested but don't want to tow it or drive it. Is this something that I can test myself? Thanks for any help.
Old Sep 21, 2009 | 02:16 PM
hazletbassist89's Avatar
Do not drive it or even start it. Are you in the vin range for the horrifying oil pump failure?
Old Sep 21, 2009 | 03:02 PM
shonuff93's Avatar
Yep. I know all about the vin#, but being that I have 94000 miles on it I don't think its going to be a problem with the block. I'm wondering if its just a pressure sensor and thats why I want to know if there are any tests that I can do myself.
Old Sep 21, 2009 | 03:11 PM
The oil PSI sending unit is cheap, $15 at AutoZone when I bought mine 2 yrs ago.
They will rent you a oil PSI tester.
Plug it in, follow the directions, simple.
Unless you are the original owner there is a good chance that this has been fixed once already.
Old Sep 21, 2009 | 03:13 PM
Never assume with a Rover.
I would suggest you go to Rover Connection and get a new oil pump and front cover to make sure, or as you have already done, look into that used one on the classified section.
Let us know how it turns out.
Old Sep 21, 2009 | 03:25 PM
shonuff93's Avatar
What else will I need when changing the pump? Any new seals for the water pump or anything like that? I really appreciate the help guys.
Old Sep 21, 2009 | 03:29 PM
You will need a new front engine cover and you can use RTV for the water pump gasket.
Old Sep 21, 2009 | 03:44 PM
shonuff93's Avatar
Should I even worry about the pressure sensor or just do the whole pump? Thanks again Spike555. By the way, where was that picture taken? Anywhere around here?
Old Sep 21, 2009 | 03:57 PM
Well its a $10 part, it might be a good place to start.
http://www.roverparts.com/Parts/NUC100280L.cfm
I would hate to have to spend $1500 when a $10 part could have fixed it.
That pic was taken in White Cloud this spring. It was a wet gloomy rainy day.
But it was fun.
devildollnyc
Dec 25, 2018 05:12 PM
importdave
Sep 25, 2014 10:18 PM
oliverRover2004
Sep 2, 2012 12:27 PM
devildollnyc
Feb 13, 2011 01:51 AM
gsgtsg
Jan 23, 2008 01:46 PM
