Air Leak puff puff puff from engine
Hello all, I have a '03 disco se, and recently I started having a puff puff puff noise coming from the engine. Took me a while, but finally found a spot in the engine where it appears the valvery cover gasket is, that's shooting out air. When you place a mirror under it, which is hard to do, you can see flame. Any ideas? No fluid leaks are noticeable.
true or a cylinder that is too rich and an exhaust leak
It "could" be exhaust leak, but I'm gonna go with a head gasket that failed at the cylinder itself. She'll sound like a WWII British Spitfire. Normally though with that kind of HG failure you'll have misfire faults. If you do and it's on one cylinder that will help narrow the problem down. If you don't have any misfire faults then it could just be exhaust gaskets.
Under it? The lower intake? Where are you putting the mirror? Sorry if i missed something. But for what its worth my head gasket blew on the top near the lower intake and it was stripped head bolts from a previous repair. The other holes in my block were also in bad shape i highly recommend head bolts it cost a little more but will probably save you a lot of heart ache if you have anything near what my 03 had. I just did a thread covering all of this yesterday if you need part numbers. Don't worry about tackling this job, it may take you a little while but its not to complicated.
I would take it apart and see what you have. Take pictures and label and bag all the fasteners according to the system they relate to. And buy stock in easy off oven cleaner if you have had any other leaks,
