Air not blowing?
Old 06-05-2012 | 07:21 PM
missalison's Avatar
Default Air not blowing?
Ok ok so I did search but couldn't find my exact problem...
Since I've owned my 2001 Disco II, she's always had some sort of small coolant leak and I have never been able to pinpoint it (usually just fill'er up and she's good to go for a couple weeks)
About two weeks ago, the top radiator hose busted. No big deal, replaced it, good to go. Well sort of... Since then, my air conditioner has stopped blowing. The compressor comes on and I can adjust temp and fan settings fine but no air blows through. If I put my hand up to the vent I can tell it's cold. I turned on the heat and it still does not blow.
Any recommendations before I take her to get checked out?
All suggestions are greatly appreciated
Thank you!!
Old 06-05-2012 | 07:29 PM
Fuse 7 inside truck, two relays, and the power transistor. See attached wiring plan.
File Type: pdf
Summer681
12-05-2023 07:21 AM
elrocha69
10-13-2013 11:24 PM
AU_LRDiscoII
02-18-2013 03:05 PM
Joseph David
03-14-2011 04:04 AM
slexum
07-23-2009 02:43 PM
Quick Reply: Air not blowing?
