Air Suspension
Air Suspension
If anyone has any info on the sls on a Disco 11 would love to hear it,
Drivers side air spring will inflate sometimes but not to full height, will also drop to bump stop when parked you can hear the valve open as you get out, Drops when driving also but will stay up for days from time to time.
Has new air pump, height sensors and no holes or leaks in bags.
If I swap the air lines from left to right the drivers side comes up to full height and passenger side stays low.
Talked to dealer service department but they wanted to start changing parts to try and find problem, So any help would be great.
Dump it and switch to coil springs.
www.atlanticbritish.com sells the kits to do the convertion for a few hundred bucks and you will never have this problem ever again.
Then you can sell the air compressor and height sensors on e-bay and get your money back pretty easily.
I need the extra rear seats in the SE7 for Kids so I guess that I will make it work. I am going to add an extra grab handle to both A pillars. I think this will be a huge help getting in and out. I have a pair of the handles that are over the front doors for this so they will match. Other than the height of the seats I sure love the Disco!!
