Air suspension - air pump
Old Nov 27, 2010 | 10:26 PM
  #21
Jeff5123's Avatar
Originally Posted by Spike555
They half assed the SLS on your truck, if you had coil springs with the air springs as helpers then your truck would not have been on the bump stops.
From what I have been told the air compressor for the SLS is not strong enough to fill a tire or a portable air tank or to run a air locker for the diff.
You can hook your air hoses back up.
well mine isn't sitting on the bumps stops.... thats odd that it's powerful enough till lift the rear end of the car but not powerful enough to fill a tank or tire...
Old Nov 28, 2010 | 05:18 PM
  #22
ringerso's Avatar
From what you describe, it looks like the previous owner, did just what they explain in the Haynes Extreme LR Discovery Manual, pages 91-93. It sounds like a nice setup, for the times that you need the extra support for hauling. They do caution that the unit should be kept at a min. of 5 PSI when you're not hauling, so as to keep the bags from chaffing. It does seem a shame though, to have the disconnected SLS compressor, not available to use for other things like filling an air tank, tires, etc...
Jeff5123: If you don't have access to the Haynes book, PM me.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
