Air suspension filter
Old Jun 18, 2014 | 09:54 PM
redwhitekat's Avatar
Default Air suspension filter
How often do you guys replace the filter for the air suspension. ?
I was thinking about replacing the filter but have never gone in the air comp box
Old Jun 18, 2014 | 10:28 PM
acamato's Avatar
The filter is behind the drivers side tail light. I replaced mine. It was not needed. I thought there was a desicant in it like an LR3. Nope, just different filters to filter out dust.
Old Jun 19, 2014 | 06:06 AM
OffroadFrance's Avatar
x2. I did a write up some time back on this. The D2 filter never actually needs replacement only cleaning and blowing out with a low pressure air line unless the foam is disintegrating. There is an inline air drier near the compressor also.
Old Jun 19, 2014 | 07:01 AM
Thanks I will clean it instead of replacing it
Old Apr 27, 2022 | 05:18 PM
nashvegas's Avatar
(random reply here 8 years later than the OP).... I replaced my suspension air filter on my 2000 recently. The foam filter inside of it had turned to utter dust. It was DRY dust.. but the foam had deteriorated completely.
So .... for those of us still running air suspension, it might be worth popping off the left rear taillight, then popping open the little black canister to check yours. There's a guy on Ebay UK (and elsewhere) selling replacement filters that you pop in very inexpensively.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
catchthebig1
Sep 24, 2010 11:57 AM
tripz
Jan 4, 2007 05:58 PM
