View Poll Results: are springs better than air
yes
28.57%
no
71.43%
Voters: 7. You may not vote on this poll
air suspension problems please help
hi guys im in ireland have problems with my air suspension i got a 00 discovery parked it on a large kerb last week and when i came back one side of the suspension was up and the other was on the bump stops so i changed the air bag on that side and still got no lift at all then i changed around the lines form the valve block and the side that was down went up and the other side stayed down and now both sides are on the bumpstops and wont stay up i think it could be either the valve block or compressor since i have changed the fuze i need all the help i can get on this one was thinking of going to springs but not sure about towing my caravan with them
Towing a caravan is where you really want the SLS it will adjust the ride with or without the weight of caravan, something that can not be done with coil spring. Even with a set of progressively wound springs its going to be stiff without the extra weight of the caravan.
thanks guys for your help you guys are great i went to brookwells landrover parts online in uk and orderd a new compressor with valve block included cost 370 euro all in so not to bad i hope this fixes the problem i will try to put it in i feel ok to do it but if its not this then i will defo need help DISCO MIKE please i will be recieving the part in the next few days if i leave my e mail on here could you send me yours so i could keep in contact thanks for your very kind offer again
fastrx7man
01-28-2012 12:49 PM
RoverDude420
02-21-2006 01:02 AM
