View Poll Results: are springs better than air
yes
28.57%
no
71.43%
Voters: 7. You may not vote on this poll
air suspension problems please help
Old Jul 31, 2011 | 02:44 PM
yozzer's Avatar
5th Gear
Default air suspension problems please help
hi guys im in ireland have problems with my air suspension i got a 00 discovery parked it on a large kerb last week and when i came back one side of the suspension was up and the other was on the bump stops so i changed the air bag on that side and still got no lift at all then i changed around the lines form the valve block and the side that was down went up and the other side stayed down and now both sides are on the bumpstops and wont stay up i think it could be either the valve block or compressor since i have changed the fuze i need all the help i can get on this one was thinking of going to springs but not sure about towing my caravan with them
Old Jul 31, 2011 | 03:30 PM
As long as you are not exceeding the tongue weight then you will be fine with springs.
Old Jul 31, 2011 | 10:37 PM
jafir's Avatar
In your part of the world they sold heavy duty springs for the rear, for towing and for the 7 passenger base model. I'd try to find a set of those.
Old Aug 1, 2011 | 03:26 AM
yozzer's Avatar
5th Gear
thanks for the reply do yuo guys think i should try to repair the air system at all? i have read on here that its better than the spring and coil system oh and if i change should i go for 2 inch lift shocks and springs or should i get the standard ones
THANKS
Old Aug 1, 2011 | 06:51 AM
drowssap's Avatar
Towing a caravan is where you really want the SLS it will adjust the ride with or without the weight of caravan, something that can not be done with coil spring. Even with a set of progressively wound springs its going to be stiff without the extra weight of the caravan.
Old Aug 1, 2011 | 09:08 AM
If you want some help on fixing the SLS issue, we should find a way to talk, do you have SKYPE?
Old Aug 2, 2011 | 04:20 PM
yozzer's Avatar
5th Gear
thanks guys for your help you guys are great i went to brookwells landrover parts online in uk and orderd a new compressor with valve block included cost 370 euro all in so not to bad i hope this fixes the problem i will try to put it in i feel ok to do it but if its not this then i will defo need help DISCO MIKE please i will be recieving the part in the next few days if i leave my e mail on here could you send me yours so i could keep in contact thanks for your very kind offer again
Old Aug 2, 2011 | 04:30 PM
yozzer's Avatar
5th Gear
drowssap that s a nice list of toys lucky guy thanks for your info i think your right bout the caravan and sls if the jeep was made for air it should have it ya? but a lot of people told me the opposite which i thought was not right thanks again
Old Aug 2, 2011 | 05:40 PM
drowssap's Avatar
no kids = lots of toys and good luck with SLS
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
cold_surfer
May 9, 2007 08:23 AM
RoverDude420
Feb 21, 2006 01:02 AM
